1982 Squealing Wheel
Old Oct 21, 2009 | 07:55 PM
ffarina's Avatar
ffarina
Default 1982 Squealing Wheel
Whenever my front right wheel gets hot - after driving for about an hour or so - it makes an awful squealing noise. I checked the brakes and rotors and everything looks good. Could it be that the bearings need re-packed? Any thoughts?
Old Oct 21, 2009 | 07:57 PM
wombvette's Avatar
wombvette
Naw, they need replacing if they are squeaking.
Old Oct 22, 2009 | 08:55 AM
7T1vette's Avatar
7T1vette
{Sounds like a Jeff Foxworthy joke...} "You might have a bad wheel bearing if it squeals like a pig..."
Old Oct 22, 2009 | 09:51 AM
wombvette's Avatar
wombvette
If your squealing wheel bearings get your pigs excited, you might be a red-neck.
Old Oct 22, 2009 | 04:07 PM
7T1vette's Avatar
7T1vette
Old Oct 24, 2009 | 08:21 AM
ffarina's Avatar
ffarina
Everybody's a comdedian - Take my wife, please! What - no swine flu or "Deliverance" references?
It is definitely the brakes - when they get hot they squeal and then when I apply the breaks it makes an awful grinding sound. I inspected the pads and the rotors and hey both seem fine. Rotors are perfect with no cuts in them. Any ideas?
Old Oct 24, 2009 | 08:31 AM
7T1vette's Avatar
7T1vette
Wheel bearing...
Old Oct 24, 2009 | 11:32 AM
wombvette's Avatar
wombvette
Check for a collapsed rubber brake line. Jack the car up and apply the brakes, then try to spin the wheel. If it is locked, loosen the bleeder and spin the wheel again. If it frees up, you have found the problem. Don't know why that would cause a grinding noise though.
Old Oct 24, 2009 | 11:40 PM
Project80's Avatar
Project80
Pull the caliper, rotor/hub off and actually inspect the bearings. Once rolling pins in the bearing get some damage, they stop rolling and start sliding. This when the real damage starts to happen.
To 1982 Squealing Wheel
