Next problem on Bubba's 76
Old Oct 22, 2009 | 12:38 AM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
Default Next problem on Bubba's 76
Worked out my tach problem, now the next. I have no ACC. That is the ACC position on the ignition switch. Turn the key to the ACC position and nothing. Electrical system comes to life fine in the "ON" position but nothing at the ACC position. Where should I start troubleshooting???
Old Oct 22, 2009 | 10:21 AM
ja1724's Avatar
ja1724
St. Jude Donor '12
I have the same problem with my 69 ( I haven't fixed it yet ) but here's what I'm going to check:
1) Ignition switch under the dash attached to the column (most likely culprit, bad contacts, loose connection etc.) Mine also sticks in the crank position.
2) Canister switch in the column (not very likely as there are no electrical connections directly connected here)
3) The actuator rod ( connects from the canister switch in the column to the ignition switch. It could be out of whack so that the ignition switch nevers fully reaches the ACC position.
I know mine is VERY old, maybe even original, I will probably change it either way.
Old Oct 22, 2009 | 02:03 PM
mysixtynine's Avatar
mysixtynine
Sounds like the ignition switch down on the mast of the column.
Unless buba made the actuator rod up out of coat hanger and its the wrong length....
I know the switch is somewhat adjustable maybe you need to loosen it and slide it up toward the steering wheel and lock it back down.
If not, its a pretty easy swap out. Very common switch. I think there were 2 different ones (tilt and non tilt switches).
Old Oct 26, 2009 | 04:56 PM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
Update: Finally crawled upside down and looked at the steering column. Found the ignition switch and mounting bracket. Loosened the two bolts, slid the switch forward on the column and tightened. Tried the ACC position and BINGO, ACC works. Thanks guys.
Old Oct 26, 2009 | 05:50 PM
joes86vette's Avatar
joes86vette
Oh that's Just awesome! You gotta love the Easy Ones
Old Oct 26, 2009 | 08:12 PM
Kahle76's Avatar
Kahle76
Is this Bubba thing a virus? I believe that they have attacked my 76 many times. I even found a twistie tie holding a part of my door lock together.
Old Oct 26, 2009 | 09:43 PM
7T1vette's Avatar
7T1vette
I don't think Bubba did that one...maybe his cousin, Rufus. Bubba would have designed a "fix" that would permanently damage other hardware should you try to repair it.
To Next problem on Bubba's 76
