EXPERTS: Need Help with Interior Lights
Old Oct 21, 2009 | 06:47 PM
CFD E59's Avatar
CFD E59
Default EXPERTS: Need Help with Interior Lights
Hi everyone and thanks for reading. I have a 70 convertible and since getting it back on the road I never put interior bulbs in. Well I put bulbs in today and the lights would not turn off, I checked the headlight switch and it is not turned on to interior lights. Looking for help to diagnous the problem. Where do I start? Door ajar switch or courtesy/alarm switch? don't know. Help.... I am getting power to all 3 courtesy lights.
Old Oct 21, 2009 | 06:56 PM
jetjockey's Avatar
jetjockey
Forward jamb switches, is where I would start.
Old Oct 21, 2009 | 07:15 PM
...Roger...'s Avatar
...Roger...
The courtesy lights have power all the time , the headlight switch and the door switches provide a ground so the bulbs will light. The white wires are the ground wires, if any of the whites are grounded the bulbs will light.
As mentioned above the door(jamb) switches are probably at fault.
Old Oct 21, 2009 | 07:42 PM
7T1vette's Avatar
7T1vette
Door jamb switch(es) and/or wiring...
Old Oct 22, 2009 | 05:10 PM
Alan 71's Avatar
Alan 71
Hi CFD,
Have you tried pushing the plunger on the switches with the doors open to see if that turns the lights off? Some times the switches need to be turned out a couple of threads to make sure the door pushes the plunger far enough.
Regards,
Alan
Old Oct 22, 2009 | 07:08 PM
CFD E59's Avatar
CFD E59
Thanks Alan71, I did try that just today still wont go off.
Old Oct 22, 2009 | 07:09 PM
...Roger...
Originally Posted by Alan 71
Hi CFD,
Regards,
Alan
Don't some of the years use a piece of rubber between the door and the plunger or is that the door ajar switches ?
Old Oct 22, 2009 | 07:30 PM
CFD E59's Avatar
CFD E59
Thanks ...Roger... Yes you are correct the rubber spacer pad is on the car but that is for the Door Ajar Switch. Thanks for the earlier reply I checked the switches today in jams and apear to be working, I'm going to be upluging them this weekend to check if ground is still active.The white wire check was a help.
Old Oct 26, 2009 | 09:51 PM
CFD E59's Avatar
CFD E59
Thanks to all who replied. I figured it out, years ago I had an alarm installed, they Bubba'd it...Thanks for the help.
To EXPERTS: Need Help with Interior Lights
