L48 engine tear down
Old Oct 24, 2009 | 07:07 PM
dgood's Avatar
dgood
Default L48 engine tear down
I have a small oil leak from the head on the passenger side below the rear spark plug. Engine still runs good so I think i am going to pull the heads, and take them up to the machine shop and see if they can rebuild the heads and clean them up. What else should I do while I am in the engine. I am not very engine smart so I do not want to get to involved in it. It is a stock 350 with an eldebrock intake holley 600, headers going back to dual exhaust. The guy I bought it from said he put a racing cam in it but other than that, I don't know anything about the pistons or cams. Looking for opinions and options. I also have a 3 speed auto with a shift kit (not sure what kind). Thanks for the ideas.
Old Oct 24, 2009 | 08:14 PM
7T1vette's Avatar
7T1vette
Are you sure that your leak is from the head and not from a valve cover/gasket? An oil leak from a cylinder head is pretty rare unless it is from a porous area that opens to a drain-back hole or a head that develops a crack in it. Clean the area of the leak off well with a solvent so that it is free of oil/grease and dry. Run it for a few minutes and check it again. I'm betting on a valve cover gasket leak....
Old Oct 24, 2009 | 08:20 PM
wnmech's Avatar
wnmech
It could also be your aftermarket intake coming from the "s" shaped seal on the rear on the intake.
Old Oct 24, 2009 | 08:32 PM
Duane4238's Avatar
Duane4238
I'll go along with that! I had the same leak on the pass. side on my '72 350. At first I thought it was the valve cover gasket so I replaced that. Leak continued. Removed my Edelbrock Performer manifold and replaced the intake gasket set with new felpro gaskets. Used RTV on front and back of intake instead of the rubber S gaskets and the leak is gone and my garage floor is clean again. Good luck!
Old Oct 24, 2009 | 09:28 PM
dgood's Avatar
dgood
I will try this. This sounds alot easier than taking the heads off. Duane, you didn't use the s gasket at all? I guess I could try that. I may try changing the valve springs and seals while I am at it and in the engine. Got any pointers on that? I will skip pulling the heads. Thanks again.
Old Oct 24, 2009 | 09:44 PM
hwcoop's Avatar
hwcoop
Edelbrock say not to use the end gaskets...just rtv
http://www.edelbrock.com/automotive_.../2000/2101.pdf
Old Oct 24, 2009 | 10:56 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Invest 20 bucks in an oil leak detection kit, once you have one you will wonder why you never had one before, an oil drip under the oil drain plug could be coming from the back of the valve covers or anywhere else, the oil goes to the lowest point, you will be amazed at where it is actually coming from, very rarely where you think
Old Oct 25, 2009 | 09:56 AM
Rmorgan&11's Avatar
Rmorgan&11
You said you do not want to get too far into the engine ? Pulling the heads is not that easy ! Still have to deal with getting valve train set back up ....etc...
Old Oct 25, 2009 | 01:54 PM
dgood's Avatar
dgood
I am going to go with the above advice and stick with the intake and valve cover gaskets. If that doesn't work, then the heads will come off with some help from here.
Old Oct 25, 2009 | 03:44 PM
TimAT's Avatar
TimAT
When you get the intake off and everything cleaned up, wipe EVERYTHING down with alcohol, then install the side gaskets for the intake with a small bead of 3M 8001 around the water jackets, then a fat bead of RTV across the ends.
Using alcohol removes all traces of oil- RTV will not stick to anything that has even a small trace of oil on it.
Old Oct 25, 2009 | 08:28 PM
rcrchsr16's Avatar
rcrchsr16
A couple of things here. I'd replace the valve cover gaskets first, then look again after driving the car a while for leaks- after cleaning off the oil at the suspected spot. Don't forget to make sure where the hold down bolts go thru the covers to tap down that area to make a flat surface across where the gasket will go. That is a notorious spot where overtightened bolts bend the valve cover.
If you can do it, you can clean the area where the intake meets the cylinder head with carburetor cleaner or contact cleaner (used in electronics and available at Home Depot) and then apply by finger some rtv silicone to get a temporary seal. If it holds, then you'll know that that's where your leak is. I'd make an extra effort here to aviod removing the intake.
To L48 engine tear down
