Help With Valve Springs
Old Oct 28, 2009 | 04:41 PM
jordan89's Avatar
jordan89
Default Help With Valve Springs
I'm looking into rebuilding the cylinder heads on my 78 Camaro, I know it's not the vette, but I need help figuring out what I need to do to install this spring kit on the heads:
http://www.summitracing.com/parts/SU...0/?image=large
Will there be any machining required on the heads, if so how much should I expect to pay?
Can anybody explain to me how the Viton valve stem seals are installed, do they go over the stock o-ring seal on the valve?
I bought a 350 engine a while back with 30,XXX miles and want to put it together and am using this spring kit because I don't know the lift on the cam, the previous owner said it was in the low .500 so I think this kit will be perfect. I tried asking these question to the Summitracing tech people, but got no reply. I want to install these things myself so I can learn.
Old Oct 28, 2009 | 06:50 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
I need to know what level of mechanical knowledge do you have and the access to tools to do this job? You are getting into an area that is not hard to do...so to speak...but with out the proper tools...you are fighting an uphill battle.
AT 30,xxx miles on the engine...why are you changing the valve springs????
Are you doing this with the heads still on the engine?????
Have you already removed anything to start this process?????
Also remember...that just replacing the valve springs and seals...with the heads on the engine...will not let you know the condition of wear on the stem of your valves and if your valve guides are bad....which replacing the valve guides should be preformed by a good machine shop.
"DUB"
Old Oct 28, 2009 | 09:54 PM
jordan89's Avatar
jordan89
"DUB"
The engine is sitting on a stand and I am mechanically inclined. I have the tool for the valve springs and have already removed the broken valve spring and the other components. I'm changing the springs because the guy bought the engine from said that the spring broke due to the cam being too big, and there is only one spring that broke.The heads are off and the engine looks pretty solid. The heads that I'm planning on rebuilding are the ones that are on the camaro, and I'm doing these heads because they have bigger valves. So, will the springs fit the stock heads, or will there need to be machining so that the springs will fit?
Old Oct 29, 2009 | 01:20 AM
OMF's Avatar
OMF
Yes that spring kit will drop right in......no machining required
The seals will just push fit on the valve guide, and if you have the little o ring seals just pitch them in the trash....not required with this type of valve seal
Old Oct 30, 2009 | 12:09 AM
jordan89's Avatar
jordan89
The people over at summitracing told me that this spring kit needs .530 valve guides for the viton seals, does anybody know the stock guide diameter on small block chevy heads? If necessary, how much should I expect to pay for the installation of the valve guides?
Old Oct 30, 2009 | 10:27 AM
jackson's Avatar
jackson
Recently changed seals in stock early 70's iron sbc heads. Just for my own info I quickly measured a coupla guides. They had Not been cut and OD measured about .560"-.570". I replaced stock O-rings with sealed power p/n mv-1233c and added drop on umbrella p/n mv-1598c. I used stock springs... but 2 good drop-in springs for you to consider are pioneer rv-943x and rv-1943x. If you're at about 500 lift then rv-943x good for you ... aka "Z-28" spring though it actually has nothing to do with a Z28. Best advice I can offer here is that you should measure lift before you proceed further ... first KNOW what you have.
Old Oct 30, 2009 | 05:41 PM
jordan89's Avatar
jordan89
Are the viton stem seals go pushed down all the way to the valve guide, or how are they properly installed? Does anybody have any pictures if the seals installed? Also are they suppose to fit on there very tight?
Old Oct 30, 2009 | 06:23 PM
Ironcross's Avatar
Ironcross
Default 4726 guide tool
The seals in the kit other than the 'O' ring seals will not fit over his guide without using the 4726 guide cutter that is shown in the link with the spring kit. His stock unmachined guide is around 570 i believe and it needs to be cut to 530 with this $40 buck tool....
it will also cut the guides length shorter to make sure there will not be any retainer to guide interference with a good performance camshaft.....a very important procedure that I feel contributes to worn cam lobe problems more than the oil used.......but what do I know, ..right......
Old Oct 30, 2009 | 08:12 PM
jordan89's Avatar
jordan89
I got the spring kit today and tried to see if they would fit over the stock guides and stopped when I saw that if I pressed them all the way down the seals would get stretched out. So would I have to install new .530 guides, or do I just have to cut/shorten the existing valve guides, with the $40 cutting tool, and drop the new seals in?
Old Oct 31, 2009 | 10:11 AM
jackson's Avatar
jackson
Again ... first measure what you have. Because of the expense involved with modifying OE guides ... Suggest you shelve/sell the kit's viton seals. Suggest you instead install seals as I did above ... both sets probably total about $10 USD at your local parts store and they slip on with no mods. And did I mention? ... Again ... first measure what you have.
Old Oct 31, 2009 | 11:36 AM
jordan89's Avatar
jordan89
What tool do I need to measure? I'm going to keep looking for those seals, I tried looking for them yesterday, but couldn't find them. Do you remember what store you bought them at?
Old Oct 31, 2009 | 11:57 AM
jordan89's Avatar
jordan89
Are these the ones you have for mv-1233c: http://shop.oreillyauto.com/productd...tNumber=MV1233
And these for mv-1598c: http://shop.oreillyauto.com/ProductD...tNumber=MV1598
So the 1233 part are o-rings, and the 1598c are umbrellas, right? And there won't be any machining needed if I use them with the summitracing spring kit right?
Old Oct 31, 2009 | 12:47 PM
jackson's Avatar
jackson
are these the ones you have for mv-1233c: http://shop.oreillyauto.com/productd...tnumber=mv1233yes
and these for mv-1598c: http://shop.oreillyauto.com/productd...tnumber=mv1598yes
the "c" suffix indicates a box of 16 & price may be less than without "c"
so the 1233 part are o-rings YES, and the 1598c are umbrellas, right? YES and there won't be any machining needed if i use them with the summitracing spring kit right? PROBABLY ... BUT ... you must measure first ... A $20 caliper will work
measure first!!!!! Just for you ... just for you I just measured an MV-1598 umbrella & it's about .150" thick at top ... so you need a "gap" at least .150" between top of guide & bottom of retainer when valve is FULLY OPEN ... so I suggest YOU go out & get yourself something halfway decent to measure with & you measure your stuff. If you don't have enough "gap" you'll quickly have problems that will Not fix themselves ... Guessing on this sort of thing is foolish. Also, I don't give a flip what dimensions are quoted online at your parts store link ... I measured ... it's about .150" thick ... I KNOW ... & you're welcome to that info.
Old Oct 31, 2009 | 01:14 PM
jackson's Avatar
jackson
Originally Posted by Ironcross
.........make sure there will not be any retainer to guide interference with a good performance camshaft.....a very important procedure that I feel contributes to worn cam lobe problems more than the oil used.......but what do I know, ..right......
110% ... sadly too often overlooked ... this is very important & there absolutely must be no interference.
Old Oct 31, 2009 | 04:02 PM
jordan89's Avatar
jordan89
Ok, thank you.I'll make sure I measure.
Old Nov 2, 2009 | 12:38 AM
jordan89's Avatar
jordan89
One more question, would using just the o-ring valve stem seals and no umbrellas be a good idea? should this be done?
Old Nov 2, 2009 | 01:41 PM
jackson's Avatar
jackson
That's exactly how all OE sbc C3 are assembled ... only o-rings. But when old guides have lotsa wear, fresh o-rings alone often aren't enough. Also, o-rings may or may NOT fit aftermarket retainers.
You have a problem with broke spring ... you Must find why it broke before you proceed ... you Must first eliminate likelihood of inadequate clearance. Measure. If you cannot do this you Must get expert local help.
Old Nov 2, 2009 | 02:18 PM
midyearvette's Avatar
midyearvette
you should use the o rings with the stock type shrouds that go under the retainer....if no shroud the o rings will not seal out all the oil...good luck
Old Nov 3, 2009 | 10:35 AM
jordan89's Avatar
jordan89
I have to use the stock shroud since the kit didn't come with them. I have some o-ring valve stem seals that I got from a Mr.Gasket gasket set that I ordered, I'm going to do some measuring to see what works.
To Help With Valve Springs
