'73 Body mount position
Old Oct 30, 2009 | 03:54 PM
Bubs's Avatar
Bubs
Default '73 Body mount position
I recently purchased a different frame for my '73 restoration. After cleaning it I found out it is a '70. I was told there is no problem other than a few of the holes for the front extensions. Now I read that the body mounts on the 73 were lowered to accomodate rubber bushings. Is this going to be another problem when I go to put the body back on?
Thanks in advance,
Barry
Old Oct 30, 2009 | 04:01 PM
stpman's Avatar
stpman
They switched from solid aluminum to rubber in 73 some say the mounts were lowered when they done this some say they didn't. If they did I don't think it was very much. hopefully somebody that knows for sure will chime in
LYLE's Avatar
LYLE
I think the 73 body will set 1/4 inch higher with the rubber mounts.
Old Oct 30, 2009 | 04:48 PM
72LS1Vette's Avatar
72LS1Vette
I used to believe that the frame mounts for the 73-up frames were lower than those for the earlier years. Looking at the AIM drawings for both types of frame shows that they are within ~1/8" of each other. The aluminum mount is ~1/2" thick and I'm guessing that the rubber mount is about the same thickness when it is torqued down.
Rick B.
Old Oct 30, 2009 | 06:36 PM
Bubs's Avatar
Bubs
Thanx for the quick responses, guess I won't worry about 1/4 inch.
Old Oct 30, 2009 | 07:49 PM
76yellow's Avatar
76yellow
I agree with all the above. Should'nt be an issue !
To '73 Body mount position
