RHS 180 Pro Action
Old Nov 1, 2009 | 06:51 AM
Little Mouse's Avatar
Little Mouse
Default RHS 180 Pro Action
Guess things can come down to what you want to believe, or testing technique to sell a product.
Thumbing through a few out dated ragazines stumbled on to this.
Ragazine test RHS 180 Pro Action, airflow
lift .200 = 120/102
lift .300 = 161/140
lift .400 = 201/170
lift .500 = 233/188
lift .600 = 248/197
lift .700 = 245/204
RHS 180 Pro Action, airflow advertising
lift .200 = 151/101
lift .300 = 207/157
lift .400 = 243/177
lift .500 = 258/186
lift .600 = 263/190
lift .700 = 270/195
Old Nov 1, 2009 | 08:11 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Interesting.
Old Nov 1, 2009 | 08:14 AM
bluzman2004's Avatar
bluzman2004
Flowbench testing comparisons are a horrible thing. You have to have so many things kept the same that it's hard to compare results unless you actually do everything on the same bench and setup. Just quickly, you have to use the same bore diameter adaptor, same radiused intake adaptor, same exhaust tube. Any of these will change your flow numbers. I can tell you for a FACT that the flowing of the RHS cylinder heads is done on a Superflow 1020 bench at Compcams in R&D and was done on all of the different part numbers as they were released, even the new CNC ported versions that are being done currently. If that article the one that was done that compared all the different small block heads, I believe that was done at Westech and again I've been there, they use a Superflow 600 bench. That is the oldest of the flowbenches being made right now (from the 70's or so) and is very manual compared the the 1020 which is computer controlled and climate correcting. All fine, if you do all the testing AND comparison on that one bench.
I run the RHS aluminum 235 cc SBC heads and they work great out of the box and made 600hp and the car runs 10's on pump gas so far. I am going to have them ported this winter though to pick up some more.
To RHS 180 Pro Action
