Half a---- shafts,help
Old Nov 1, 2009 | 04:54 PM
cadillackoid's Avatar
cadillackoid
Default Half a---- shafts,help
I just threw my tape measure n climbed out from under my 80. Aren't the h-shafts supposed to be the same length. I have 1 thats 3/8in. longer,all new a year ago. Can someone tell me correct length? And also,whats the difference between 79 & 80 outer yolks,spindles & bearings? All 80 stuff is new(not done by same as shafts)and I'm going with 79 rear. Thanks!
Old Nov 1, 2009 | 05:05 PM
cadillackoid
ttt
Old Nov 1, 2009 | 05:30 PM
Tumarr's Avatar
Tumarr
I think thats right, because the motor is off center to towards the passenger side so that offset translates in the rear also.
Old Nov 1, 2009 | 05:33 PM
cadillackoid
My 79 is equal. I can see offset in slight d shaft angle.
Old Nov 1, 2009 | 05:35 PM
bluzman2004's Avatar
bluzman2004
I don't know if this helps you or not, but I have a complete 78' rear assembly in my garage floor and measuring from center of the universals, those are the same length.
Old Nov 1, 2009 | 05:39 PM
cadillackoid
How long are they ? At this point I'm getting cautious, since it's my daily driver.
Old Nov 1, 2009 | 05:44 PM
7T1vette's Avatar
7T1vette
Aw, come on.... Both those steel tubes are exactly the length of the forearms on the Chinese guy who cut them.
Ooops! One matched his left arm and one matched his right....
Old Nov 1, 2009 | 05:46 PM
bluzman2004
13 7/8" center to center
Old Nov 1, 2009 | 06:35 PM
Jclgodale3's Avatar
Jclgodale3
No...the differential has an offset in it to compensate for the off center engine/tranny. Half shafts are the same length
Old Nov 1, 2009 | 08:53 PM
killer454's Avatar
killer454
i have an 80 vett just put new u-joints in both rear shafts i held them up to each other while they where bare no joints and they where same lenght. 1980 automatic
Old Nov 2, 2009 | 09:16 AM
bluzman2004
If you want to buy two that are the same length, I have the entire rear assembly in my garage and I'll part it out.
I also have the complete diff with Auburn posi and 4.56 gear, too!
Old Nov 2, 2009 | 10:09 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
all 80-82 shafts are 13.5" center to center
all 63-79 shafts are 13 7/8" center to center
63-79 Spindle Flange (outboard)
80-82 Soindle Flange
Old Nov 2, 2009 | 10:14 AM
bluzman2004
Van Steel,
That explains how he could have 2 different lengths.
Old Nov 2, 2009 | 11:17 AM
Tom454's Avatar
Tom454
Side note:
Ecklers lists
#4097 for manual trans 1980 & 1981 and
#4098 for automatic trans 1980 & 1981 and
#4097 for all 1982
Differences are in the U-Joints I guess.
Old Nov 2, 2009 | 11:20 AM
TWINRAY's Avatar
TWINRAY
I had a problem with this when I went to 3"' shafts.
http://forums.corvetteforum.com/c3-t...in-tow-in.html
Go to post #28 if you don't want to read the whole story.
Old Nov 2, 2009 | 12:56 PM
Van Steel's Avatar
Van Steel
Originally Posted by Tom454
Side note:
Ecklers lists
#4097 for all 1982
Correct, and all 80-81 4 spds use the same joint as all 82's. 1350 serie joints. 1330 on the 80-81 autos.
Old Nov 2, 2009 | 01:00 PM
Van Steel's Avatar
Van Steel
I remember that thread.
To Half a---- shafts,help
Old Nov 4, 2009 | 02:08 AM
cadillackoid
Can I put 79 flanges on 80 spindles? I'm putting 79 posi w/373's,79 shafts(79 4spd ujoints same as my 80)and I guess I need to change flanges.All the 80 bearings are new. But I thin my drive shaft is 1in. too short for 79 rear but joints are again same size.
Old Nov 4, 2009 | 09:32 AM
Van Steel's Avatar
Van Steel
Yes the spindle flanges from 63-79 will slide onto your spindles. All the spindles are the same from 65-82. You need to make sure that you torque the spindle nut to 100 ft/lbs. If the cotter pin hole doesn't line up, go tighter. You also need to make sure that the 79 shafts you are using have a half shaft flange on them.
You also need to change the following:
Strut rods
Strut rod bracket
Diff tongue bracket
Old Nov 5, 2009 | 08:25 AM
cadillackoid
has anyone seen this style strut bar?I've found it nowhere but my 79.
