Tools for packing front wheel bearings
Old Nov 14, 2009 | 08:45 AM
LannyL81's Avatar
LannyL81
Default Tools for packing front wheel bearings
Was wondering what others have used and their opinions of the bearing packing tools available. I once used the two cone shape tool..but found it did not work very well. Does the type with the clear plastic container and the piston work OR is it just better to take the bearings to a shop and have them done?
Old Nov 14, 2009 | 09:00 AM
7T1vette's Avatar
7T1vette
It's 'best' to just work the grease into the bearings with your hand/palm. It's messy...but effective.
Old Nov 14, 2009 | 09:16 AM
redwingvette's Avatar
redwingvette
I've been doing it that way for years but the tools being sold work just as well if you have extra money to spend, which I have been known to do a time or two.
For a job like wheel barrings, I would save the money for more important toys.
Old Nov 14, 2009 | 09:48 AM
zigvs's Avatar
zigvs
I used the 2 cone shaped one for years but it was made from machined steel.Very old tool.someone dropped it in the shop and it bent the threaded shaft. destroyed.Could never find a replacement.The plastic one sucks.I just use the palm method,its fool proof but messy.
Old Nov 14, 2009 | 10:05 AM
swampblues's Avatar
swampblues
put some grease in your hand - take the wheel bearing with your other hand and scrape the wide end of it through the grease until it starts coming (butter) out on the narrow end and between the rollers of the bearing - turn the bearing in a circle until all spaces between the rollers are filled with grease (do it twice to remove any air pockets).
simply rubbing grease on the bearing is not good enough - it needs to get between the rollers - hands and the "scraping" motion are the best tools for this one.
Old Nov 14, 2009 | 10:25 AM
...Roger...'s Avatar
...Roger...
I have used the plastic one for years and I like it but its not worth the money for a few cars. If I'm somewhere where I don't have the plastic tool I use the hand SLAP method. Put a gob of grease in the palm of your hand and slap the open side of the bearing into the grease and you will see the grease work its way up and out the other side of the bearing,this will insure the bearing is properly packed.
Old Nov 14, 2009 | 02:03 PM
mapman's Avatar
mapman
Me too, but make sure your hands are CLEAN.
Old Nov 14, 2009 | 02:22 PM
TJP440's Avatar
TJP440
We use this one
http://www.lislecorp.com/tool_detail.cfm?detail=559
seems to work well
Old Nov 14, 2009 | 03:33 PM
...Roger...
Originally Posted by TJP440
We use this one
seems to work well
Dang mine cost a lot more than that and I've had it 100 years. I got screwed.
Old Nov 14, 2009 | 05:28 PM
schmegeggie's Avatar
schmegeggie
Been doing it since I was a teenager.
Oh, wait, what are we talking about?
Seriously though, get some rubber mechanics disposable gloves and it makes the job less of a mess.
Old Nov 15, 2009 | 07:45 AM
LannyL81's Avatar
LannyL81
Okay, from the posts sounds like hand packing is still the way to go. That is the way I usually have done them. Even the time I tried the two cone shaped thing....still had to finish the job by the ole hand packing.
The inner bearing is easy, but the outer bearing is harder to hold onto.
And yes I use gloves...been using the nitite gloves for many years now just about anytime I work on a car.
Thanks for all the opinions.....gotta go get busy.
Old Nov 15, 2009 | 08:02 AM
bobbarry's Avatar
bobbarry
I've done it all ways, and I like the Lisle tool linked above best; it keeps the grease clean between uses, it fully fills the voids between the rollers in the cage, it's quick, and it's much cleaner.
The hand-method is only better if you don't have the tool available, you have the time to spare, and you like the feel of kneading greasy stuff in your hands.
Old Nov 15, 2009 | 08:45 AM
markdtn's Avatar
markdtn
We use this one
seems to work well
I also have this one and am very pleased with it. I have found that if you are doing the job in winter you need to bring the tool inside a day ahead so the grease is not so hard to move. I always wear laytex gloves and do some of the palm method after I use the tool just to be sure.
Old Nov 15, 2009 | 09:44 AM
SIXFOOTER's Avatar
SIXFOOTER
IMHO the tool is not even worth fartin with. It might work fine, but you still end up finishing by hand, still have to clean your hands and Also have to clean the tool. Faster and more efficient to just do it by hand.
Old Nov 15, 2009 | 11:10 AM
7T1vette's Avatar
7T1vette
I have 'toyed' with the idea of pouring the grease into those bearings. I've never gotten motivated enough to try it, but if you made/found a little metal [or ceramic] cup that you could fit the bearing in, one could melt the grease in a pan on a kitchen stove and pour it in to fill up the bearing, The cold metal bearing should cool the grease fairly quickly. Then, remove and install the bearing. Sounds like it would work and be easy...but I still haven't tried to do it.
Old Nov 15, 2009 | 11:49 AM
...Roger...
I want to see the look on your wife's face when she comes into the kitchen and catches you heating grease in her pan on her stove.
Old Nov 15, 2009 | 05:24 PM
Hootisit's Avatar
Hootisit
I have to agree with 7T1vette. I've always packed them by hand to guarantee that each roller has grease, it's messy, but feel it's done right.....
To Tools for packing front wheel bearings
Old Nov 15, 2009 | 05:38 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
In this whole post no one has mentioned that the first part of this process is to wash all the old grease from all bearing parts and the hub before repacking. Of course the old method that most of us graybeards used was a old pan with a gallon of gas in it. We blew the parts dry with a airgun and inspected all them for wear before repacking. Course some of us spun the bearings up to RPM with the airgun which was not a good idea. That whistling sound was neat. Kerosene is a safer choice to clean with though, I might add.
I assume that the cleaning first process was a given.
Old Nov 15, 2009 | 06:01 PM
Project80's Avatar
Project80
We use this one
seems to work well
I have an older style model than what's on the website, it works well. If you know how to use it, it's a lot faster when packing multiple bearings
At the house I pack them by hand just as swampblues posted. It's very important to get the grease between the roller pins so they don't slide. If you don't and make the grease work itself into the cage, the bearing will have some very hard miles.
Make sure you inspect not only the bearings, but also inspect the bearing race. Check the race to make sure it's not spinning in the hub. I also use a can of Brake Kleen to degrease the bearings, it evaporates off and really doesn't leave a residue.
Old Nov 15, 2009 | 08:10 PM
81pilot's Avatar
81pilot
The palm of your hand.........
