GM block #'s
Old Nov 14, 2009 | 03:53 PM
racinmann's Avatar
racinmann
Default GM block #'s
where is the best place to type in a block # and get it's year and anything else???? The # is... 3970010 and next to it has GM 33.... if anyone can help, I appreciate it.
Old Nov 14, 2009 | 04:16 PM
midyearvette's Avatar
midyearvette
350 chevy 69-80 2 0r 4 bolt
Old Nov 14, 2009 | 04:24 PM
BB72's Avatar
BB72
mortec.com
http://www.mortec.com/castnum.htm
Old Nov 14, 2009 | 04:27 PM
racinmann's Avatar
racinmann
Are you telling me the block is for a 69? I just got a 69 convertable and it has a bb 396 in it.... I wanted to take it out and if this is the case.... I know I will and put the 350 in it..... What makes it a matching #'s car??? It is a 4 bolt as well.... thanks
Old Nov 14, 2009 | 04:41 PM
Alan 71's Avatar
Alan 71
Hi RM,
There is a long list of parts that make up a numbers matching car. ( Without even thinking about whether the part is the original part the car left St.Louis with.)
On the block things to check are the block casting number and date on the rear flange of the block and the front stamp pad (in front of the right side head) for the engine assembly date with suffix code and the serial number derivative.
Here's an example of a 71 350/270 built in Jan 71. The engine was built the 7th of January and went into car number 6589.
I hope this gets you started.
Regards,
Alan
Old Nov 14, 2009 | 05:25 PM
racinmann's Avatar
racinmann
Alan... thanks for your help... I just went down and checked the #'s on it and got.... V0502TJA .... I did not see any other #'s like yours on the left side...???? why is that?
Old Nov 14, 2009 | 05:30 PM
racinmann's Avatar
racinmann
Hey midyearvette.... thank you as well... I got so excited I forgot to thank you..........lol
Bo
Old Nov 14, 2009 | 06:32 PM
Alan 71's Avatar
Alan 71
Hi RM,
TJA looks like it's a block from, or intended for, a 73 or 79 truck. The block casting number will help determine which year.
I'm not sure why there's no vin stamp.
Regards,
Alan
To GM block #'s
