MPG Improvement
Old Nov 15, 2009 | 08:11 PM
Tommy Almond's Avatar
Tommy Almond
Default MPG Improvement
I have a 1981 stock vette, 350 engine, 4 bbl carb w/auto trans and get about 10 to 10.5 mpg. Are there any thoughts on improving mpg that I might consider? I will entertain all, low cost and high cost options but wanted to start here for others of you may have solved this prior. Thanks in advance for your responses and comments.
Old Nov 15, 2009 | 08:32 PM
mrvette's Avatar
mrvette
TPI done out of junkyard parts, some wiring talent, and a aftermarket Cal Pak remains the most simple mod possible for fuel economy...
whole thing costing less than 700 bux these daze....BUT you have to wire your own harness...otherwise some clowns will want over 300 bux for a few wires with crimp connections and chunks of plastic...
Old Nov 15, 2009 | 08:38 PM
Hammerhead Fred's Avatar
Hammerhead Fred
That's awful low for a stock vehicle.
When's the last time you tuned it up?
You should be getting 15/21 city/hwy with an auto.
I get 16-17 on the hwy with my 72.
Old Nov 15, 2009 | 09:46 PM
trw's Avatar
trw
I get 14 on the road with my 454.
And about that (10-10.5) in town.
Old Nov 15, 2009 | 11:28 PM
R C's Avatar
R C
2nd Gear
I checked my 77 L 48 with a 4 speed this weekend and got 16.1 MPG. Bone stock.
Old Nov 15, 2009 | 11:47 PM
martinsw's Avatar
martinsw
I agree with previous posters that you should be getting better mpg. When my 79 had the stock 350 / TH350 I got about 15 mpg combined driving.
Tune up w/carb overhall should help out before major mods....
Old Nov 16, 2009 | 09:23 AM
bashcraft's Avatar
bashcraft
That is bad. My 502 with 3.55 gears and M-21 gets 12-12.5.
How heavy is your foot?
Old Nov 16, 2009 | 09:33 AM
Mike Ward's Avatar
Mike Ward
Stock engine and 10 mpg? You have a serious engine problem or a lead weight in your right shoe.
Can't help you if it's the second one.
Old Nov 16, 2009 | 09:43 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Just checked mine after a recent road trip - I got 16.1 mpg with my '78. Sounds like you might have a bad carburetor idle/transition mixture, lack of vacuum advance, dirty plugs or bad ignition, retarded spark, high rpm (low rear end gears), or just poor driving technique.
__________________
1978 Corvette
406 SBC AFR heads Lunati roller Quadrajet TH-350 3.08
11.59 sec / 118.9 mph 1/4 mile
Old Nov 16, 2009 | 09:55 AM
7T1vette's Avatar
7T1vette
An '81 with the stock CCC computer/dist/carb system [which is working correctly] should get 20 mpg on the road and about 15 in town. If that equipment is still on the car, get a copy of the Chevrolet Chassis Service Manual and follow the steps for check-out and set-up of the CCC fuel management system. If the CCC stuff has been stripped off the engine, but you still have the original carb, that is your problem. The fuel enrichment system isn't getting any feedback from the computer and it stays at "full-rich" position all the time. In that case, swap out the stock '81 carb for an all-mechanical carb and tune it properly. Lastly, if you have a standard carb on the engine, tune it up [and/or rebuild it], adjust timing per Lars Grimsrud's papers (CF Archives) and you should be in good shape.
Old Nov 16, 2009 | 06:05 PM
Tommy Almond
Thanks for the info. Yes it still has the CCC compontents all on the car and I have the service manual so will start reading up on checking the system.
One thing I do know is the "check engine" light does not come on at start up so may be an issue there.
There is no smoke from tailpipes and car will run strong. One thing different is that it has a Jasper motor installed instead of the original one so something may not have gotten hook up right.
I own the vetter about 2 months now so going thru it slowly.
Old Nov 16, 2009 | 06:18 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
FWIW, the tri-power 427 BB w/manual trans & 3.55:1 rear combination formerly in my '78 was capable of ~14 mpg, which was a significant improvement over anything I ever got with the original L82/auto & 3.55:1 combo...
Old Nov 16, 2009 | 06:26 PM
7T1vette's Avatar
7T1vette
Tommy...
The '81 CCC system is an OBD-I system which has the capability of displaying "trouble codes" via a flashing Check Engine (CE) light. There may be info on how to get a "dump" of stored trouble codes in the Chassis Service Manual, or you can search the web for that info. It must be specific for the '81 year, though; no computer on '80s and a new OBD-II system for '82 and later.
Since you have all of the CCC equipment in place, that is the best way to go. Even if you find some of the equipment is defective, there are working parts 'out there' from those who are dumping that system for EFI or just a basic carb set-up. I would bet that the O2 sensor is kaput and some of the other sensors may be past their useful life. Sensors are relatively cheap compared to swapping out the entire system, however. Good luck.
Old Nov 16, 2009 | 08:29 PM
Hammerhead Fred
For future reference: Jasper motor <> Stock Vette
If the PO went to the trouble of replacing a Corvette engine with a Jasper motor then there's no end of possible issues you could be facing regarding fuel consumption.
Old Nov 16, 2009 | 11:02 PM
Attfay Elleybay's Avatar
Attfay Elleybay
I haven't tried it yet, but Matt Gruber (on this forum) say a major mpg improvement with a 4 hole spacer under the carb. I agree with the rest that you need a tune-up.
Old Nov 17, 2009 | 02:47 AM
Peterbuilt's Avatar
Peterbuilt
Here's the base of a spare carb (7028212) that I use to experiment with. I don't see any holes to block off so I never followed up on this improvement. I hope MG can enlighten me.
The carb on my car is a stock 4MV 7044206 and I get 13 MPG around town (stop & go) at speeds between 35 & 45 MPH. On the highway I get about 17 MPG. My original and stock carb has no extra holds to block either. Stock 74 350 auto th400 with 3:08 rear cast iron manifolds and true dual chambered exhaust.
Better mileage would sure help but I don't seem to be able to follow your information, what am I missing? PG.
Old Nov 17, 2009 | 05:39 AM
Matt Gruber's Avatar
Matt Gruber
that carb sure needs a 4 hole gasket to work right. an open gasket could mess up the mpg, IF it has a cam with more overlap than stock. nothing wrong w/17 on the highway w/TH400. seems normal to me.
If others want to see what we are talking about see my article http://community-2.webtv.net/MATTGRU/carb
To MPG Improvement
Old Nov 17, 2009 | 08:05 PM
Tommy Almond
Sorry about saying stock when has a Jasper motor; meant stock in that no high performace work or modification has been done to car.
Old Nov 17, 2009 | 08:07 PM
Tommy Almond
Good to hear from you and see you are from Mt. Holly. I live in Lucia so we may cross paths one day. Be good to meet and swap some ideas.
Old Nov 17, 2009 | 09:41 PM
Peterbuilt's Avatar
Peterbuilt
Thanks for posting the link again, now I think I understand what you mean. I have a Q-Jet with the 4 hole gasket but not one that is 1/4 inch thick.
