head choice
Old Nov 24, 2009 | 08:05 PM
  #61
no4n4me's Avatar
no4n4me
Originally Posted by billla
I think it's pretty easy to net out:
  • Head choice needs to be matched to the vehicle, not just the engine.
  • Head choice is based on priorities for the engine. (max power, street driving, etc.)
  • Flow only benefits the combo if you use it. (cam, gears, trans, driving style etc.)
  • Think long-term and buy the head for where you - realistically - want to be.
  • Tony is a cool guy and we're lucky to have his expertise on the forum.
Gosh, these sound so familiar...
I listen and read very closely because when it comes to heads, cam, lift, duration... I know nothing. When Tony posted 12 hours prior to my last post I had already made the order. It came today.
AFR 180's , RPM Performer manifold, Valve covers, Lunati cam with lifters, Lunati rocker rollers, 2400 stall torque converter, Summit gear drive timing set. and all the bolts and gaskets to put it together.
What we want is a respectable street car. We will never go to the drag strip with it, but there will be times it will see a show of acceleration. Especially at the lights when the over populated mustang makes a show.
SO that brings me to the timing gears. Are the Summit gear drive timing gears junky? I am sure I will be able to return them for a different set. I will be using gear drive timing though. Chain or belt is not in my future.
Thanks guys I really do appreciate everyones input, Marty
Old Nov 24, 2009 | 08:19 PM
  #62
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Timing gears are on the noisey side, good choice with the AFR 180 heads.
Old Nov 24, 2009 | 09:47 PM
  #63
flynhi's Avatar
flynhi
Originally Posted by no4n4me
Full roller would be awesome. I wish we could go roller cam too but with the carpet set and brake kit along with this engine upgrade my budget is getting tight for this round.
Funny thing about it is I am the one trying to hold the spending down while the Mrs. is yelling more, more, more...
You can do the carpet anytime - get the engine right while you have the chance.
Old Nov 24, 2009 | 10:01 PM
  #64
VetteRed1965's Avatar
VetteRed1965
Ord where ?
Old Nov 24, 2009 | 10:32 PM
  #65
billla's Avatar
billla
St. Jude Donor '14
There is no reason in the universe to run gears on a street engine, period. Invest in a Cloyes Tru-Roller and call it good.
There's also no reason to run full roller rockers on the street, but that'll start a big OT discussion so we'll just end on that IMHO note
Good luck with your top - I'm sure you'll be very happy with your combo.
Old Nov 25, 2009 | 06:20 PM
  #66
dp9's Avatar
dp9
I know one! they sound really cool!
i just cant help contesting absolutes.
Old Nov 26, 2009 | 05:13 PM
  #67
no4n4me's Avatar
no4n4me
That's what I am thinking.
Old Nov 26, 2009 | 05:52 PM
  #68
billla's Avatar
billla
St. Jude Donor '14
Gear noise from an engine that's making < 1HP/CID doesn't impress me much...but it is a cool sound.
I guess I don't understand spending money on sound vs. power...but that's just me. I look at cool sound as a byproduct of cool power. But...everyone to their own
Old Nov 26, 2009 | 06:11 PM
  #69
dp9's Avatar
dp9
yeah, i hear ya on it being a byproduct. thats why its cool, and why people want. theres a market for appearances. they do make and sell "noisier" gear drives. and also the comp cams thumper cam line is made just for the right exhaust sound. makes a lot less power than a similarly spec'd XE or Magnum line cam. I think mufflers are in the same boat too. if your not running straight pipe, or the highest flowing mufflers available (if you cant run straight pipe), its all for the sound (of power).
