Help, Adjusting Headlights
Old Nov 19, 2009 | 07:57 PM
Tim81's Avatar
Tim81
Default Help, Adjusting Headlights
I have the top adjusting screws all the way in causing the lamp to raise up, but the light beam at night is still pointing at the ground about 10 feet in front of the car. They also seam to point to the center of the road. Any ideas to correct for this would be great. I can't see the road to drive at night... Thanks Tim
Old Nov 19, 2009 | 08:15 PM
08vycpe's Avatar
08vycpe
Are you sure the lights are fully in the up position and locked in place? I would make sure that mechanically every works and is mounted correctly and there is no physical damage. There is an alignment procedure in the AIM or the service manual. I've used the procedure and it works well.
Old Nov 19, 2009 | 08:56 PM
Tim81's Avatar
Tim81
Thanks for your reply. Yes, I'm sure the light are all the way up, the top of the lamp bucket is touching the upper mounting tab. I agree something mechanically is not right. The car has stand halogen lamps that seem to be mounted correctly..
Old Nov 19, 2009 | 10:56 PM
spedaleden's Avatar
spedaleden
Tim81 send me your email address. I have a diagram on how to set up your headlights
Old Nov 20, 2009 | 06:43 AM
Phil Zell's Avatar
Phil Zell
Please send me one also
philzell@msn.com
Old Nov 20, 2009 | 06:46 AM
JimT's Avatar
JimT
How about posting a link to the diagram! I'm sure many of us would like to see it. I've got the same problem.
Old May 25, 2011 | 06:39 PM
76Vett's Avatar
76Vett
Same problem here also - buckets all the way up but beams are pointing to the ground. If you could post that link, I'd sure appreciate it.
Old May 25, 2011 | 06:47 PM
Alan 71's Avatar
Alan 71
Hi,
On earlier cars, at least, there are 3 screws (1 top, 2 sides) that aim the headlight cups.
Regards,
Alan
Old May 26, 2011 | 09:03 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Hey Tim, how's the rebuilt engine?
Haven't read anything on your budget - well almost budget - rebuild? Does it run? Any results?
If your moving the headlights then somethings gott'a be pulling the vacuum.
cardo0
Old May 29, 2011 | 08:29 AM
imariver's Avatar
imariver
I don't think the OP has a problem with "system" If you look at and study the pic that Alan71 posted, you should be able to see if the headlight is pointed in the right direction, (to a certain extent) If you have to set the adjusting screws to their max and the light is still not pointed correctly, then I would suspect a defecrive lamp. Try swapping left and right lamps. See if the problem migrates.
Steve
Old May 29, 2011 | 12:40 PM
Alan 71's Avatar
Alan 71
Hi,
Also, since the 4 cups are different from each other... could them being in the wrong place affect the ability to aim the headlights properly?
Regards,
Alan
Old May 29, 2011 | 09:05 PM
Tim81's Avatar
Tim81
Wow, I thought this post was dead long ago. Thanks for the photo Alan71. To be honest with everyone the headlamp problem was put on the back burner while I was rebuilding the motor. Now that the motor is done I will get back to the lights. Cardo, the engine came out great it runs like a top and I can not believe the difference in power. Broke the budget by about $600.00 but it was worth it..Tim
Old May 29, 2011 | 09:34 PM
cardo0's Avatar
cardo0
Default Congrats on getting it running.
Good to read of your success with the rebuild - we need more of that here on the forum. I frequently read of first time rebuilders trying to do too much on the learning curve. Now that you've been there your next try at a performance rebuild will be soo much easier and you will know were to spend your hard earned $$$. 600 bucks is hardly even one visit to the dealership these days.
Your the expert now Tim,
cardo0
To Help, Adjusting Headlights
