Hey guys,
Does anyone know what's involved in taking apart/ rebuilding the rear spring on a '72? I'm rebuilding everything in the rear of the car (it all started with a leaking pinion seal on the diff.), have removed the trailing arms and everything else for rebuild and am now looking at the spring. I don't think it needs to be re-arched as the ride height/ stance of the car looks about right. I just want to take the spring apart , repaint, and put in new liners.
Hi G,
The rebuild is straight forward once the spring is out of the car. The paint and liners are available from many vendors, I like Quanta Products.
Notice there's 1 less liner than you'd think! None at long flat leaf.
Regards,
Alan
Hi G,
Regards,
Alan
Thanks Alan. Is there anything special about removing the center bolt in order to disassemble the spring?
When I did mine, it was rusted through and in two pieces anyway. Nothing special that I could see, other than it will be under a bit of tension as you unthread it. The replacement bolt that I ordered was much longer than it need to be, making it easier to get started. I trimmed the excess length after I tightened it down.
I suppose you can use a c-clamp to hold the leaves together, remove the nut and bolt, then release the tension by loosening the c-clamp.
Hi G,
T72's info is right on about watching the length of thre bolt. I was able to save my center bolt with some rust buster but often they're so rusted the nut twists off. Good luck with yours.
Regards,
Alan
temvette72
Yeah, that's what I was concerned about - how much pressure the spring leaves were under when I take the screw out. Thanks for the help, doing this is a lot cheaper than buying a new spring and then trying to correct ride height, etc.
Hi G,
Regards,
Alan
Thanks Alan. After I'm done with the spring I'm really looking forward to putting everything back together after I get my rear end pieces back from rebuild.
It's really not worth fooling with the old bolt. There is a reason new bolts are so long. A 6 or 8" center bolt is less than a dollar at a truck supply.
If using a new bolt, make sure the head is shallow enough to not protrude in mount, otherwise you could pop the casting. You can grind the head down to fit recessed.
I didn't replace the liners, they hold a lot of moisture. You can see the rust pits in the old leaf. Depends how much rain your car will see. Check to make sure yours a good.
Is the old spring still adequate? The easiest way to repair it is to take it to a truck spring shop and let them rebuild it right. I doubt you have the size vise you need to take it apart [or reassemble it] properly.
The spring is adequate I think - the ride height looks good. Mainly I just want to clean it up, paint it, new liners, etc. I was thinking a couple good c-clamps would hold the spring together when I took the center bolt out. Is a big vise required to do this?
Hi G,
I'm not sure what 7T1 is referring to, I took my spring apart and put it back together without an special tools. Once the trailing arms are dissconected the spring is in it's relaxed state... it comes apart easily. (at least mine did)
Regards,
Alan
C-CLAMPS WILL WORK. I DID MY DAYTONA SPRING FOR MY '66 LAST WEEK. WAITING FOR THE PAINT TO DRY TOOK THE LONGEST. BE SURE TO LUBE BETWEEN THE LEAVES.
BILL SR
