Battery drain
Old Nov 24, 2009 | 06:31 PM
murfthsurf's Avatar
murfthsurf
Default Battery drain
I have a 78 vette. Put in a new battery but if i dont drive it every day the battery goes dead. I took the negetive post off the battery and put a tester beteween the battery post and the cable, I'm getting 12 volt reading on tester with the key off. I'm guessing that something in the car is still on draining the battery. How can i trace it down.
Old Nov 24, 2009 | 06:37 PM
...Roger...'s Avatar
...Roger...
Your 78 has a delay on the courtesy lights that you will have take in to consideration. Here is a test in this thread that should help.
http://forums.corvetteforum.com/c3-g...with-pics.html
Old Nov 25, 2009 | 06:29 PM
murfthsurf's Avatar
murfthsurf
Thanks very helpful.Did not solve problem. I pulled out all the fuses and wires in fuse panel,tester light still stayed on. Unpluged the harness that goes to the stater light went out. It has to be something that does not go through the fuse panel. Or maybe fuse panel has a short? I dont have any wire stymatics maybe that would help.
Old Nov 26, 2009 | 01:30 PM
adam's Avatar
adam
Doesn't the 78 have an anti-theft system ?
Once a day is a little excessive. But if you fix that you may still want a battery
tender, or a disconnect switch. Harbor Freight has the side post disconnects.
Old Nov 28, 2009 | 09:48 AM
rgranata's Avatar
rgranata
check your alarm relay inside your center console that was my problem on my 1980 if it makes a clicking sound when battery is shut off its bad i took mine out no problem since good luck
Old Nov 28, 2009 | 03:31 PM
SSG26K's Avatar
SSG26K
Hook up an amp meter between the battery and cable. Battery drain is measured in amps, not volts. Shut everything off and close the doors. The amp meter should go all the way to ZERO in about 40 seconds. If you have a reading of 1/2 amp or more; look for a bulb that is on.(glove box, hood light etc.) If your reading is about 1/10 of an amp then look for electronics that are putting the drain on your battery.(Key warning/ seat belt buzzer, radio)Mine was the buzzer. Start by pulling fuses that are always hot with the key out of the ignition. This will locate the circuit that's bad. Remember to close the door after you remove each fuse and let the interior lights time out. Now get an electrical diagram to show you all the items in that circuit . Good luck.
Steve
Old Nov 28, 2009 | 06:13 PM
71coupe454's Avatar
71coupe454
I got a diagram from somebody in here...maybe do a search for the thread, it was on the first page within a couple days ago.
Old Nov 28, 2009 | 08:19 PM
nutsy's Avatar
nutsy
Steve
even with door closed wont clock, at least in my 72 draw power?
Old Jun 17, 2020 | 03:50 PM
SwampeastMike's Avatar
SwampeastMike
The brake warning lamp is supposed to come on when you're cranking. This is a bulb check.
Old Jun 17, 2020 | 03:53 PM
speedreed8's Avatar
speedreed8
Check the light in the glove box too.
geez!! 2009. Fooled again
Old Jun 18, 2020 | 08:20 PM
7T1vette's Avatar
7T1vette
Horn relay or alternator are the only electrical items that get battery power WITHOUT going thru fuses/breakers. They have fusible-links which still can carry current when ignition is OFF.
Disconnect 'hot' wire on alternator (cut battery first!) to start, since that is the easiest to check. You could have a failed diode in the alternator which is leaking current 'backwards' (rather than blocking that current flow).
Old Jun 18, 2020 | 08:24 PM
MelWff's Avatar
MelWff
I think you guys are answering a thread from 2009
Old Jun 18, 2020 | 11:47 PM
ignatz's Avatar
ignatz
Hell it's from 'murph the surf', worth a try! Apparently he's been hiding out in Oklahoma.
To Battery drain
