Best Carb suggestions?
Old Dec 4, 2009 | 04:09 PM
  #41
71coupe454's Avatar
71coupe454
I found a reman q-jet locally for $279.00, Same place I got the one on my 79 Z-28 12 years ago that I have only cleaned with carb clean since then. I'm searching online for a price on the Holley, nobody near me has the speadbore type. I got a Tech at work that has a 5-gal bucket of loose Q-jet parts at home, Can anybody tell me if the bowls are different or what to look for to tell if will replace my cracked one? I was told mine is a 1975 model carb.
Old Dec 4, 2009 | 04:29 PM
  #42
manofsteel1's Avatar
manofsteel1
I have the Eldelbrock600 or 650 on my 350 1973 vette and it runs good. Tho, not great. Seems to have bad gas mileage. Has lot's of get up and go
Old Dec 4, 2009 | 07:40 PM
  #43
71coupe454's Avatar
71coupe454
Originally Posted by Matt Gruber
4165 is best.
As for what gasket? Do u have a working heat riser? I haven't used carb heat in decades. U'd need like what was on the qjet, w/stainless steel to keep fumes off.
That heat could of melted the epoxy on the old carb. It didn't boil in summer?
this what I was asking about from your page "Be sure to get the 108-21 base gasket; very important!" Is that a holley part number I will find where I get the carb?
Old Dec 4, 2009 | 08:01 PM
  #44
nitronick's Avatar
nitronick
Active Streak: 90 Days
Sometimes the bowls will interchange, most times not. I would need the number from yours and the number form the prospective bowl to tell you.....
Old Dec 4, 2009 | 08:37 PM
  #45
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Originally Posted by gingerbreadman1977
bolt on a demon 750 DP or a holley and start flying.... set your transission slots to .020 before you bolt it on, set you mixtures with a vacum gauge and thats it.
Doesn't matter what carb you get. If you don't set it up for your car, it won't work worth a damn. Trust me.... I know.
Old Dec 5, 2009 | 12:02 AM
  #46
71coupe454's Avatar
71coupe454
Looks like about $400 bucks is what the holley runs about anywhere I can find it. Will my old coil choke mounted to the intake hook to and work with the 4165 holley?
Old Dec 5, 2009 | 12:44 AM
  #47
baxsom's Avatar
baxsom
no, that is a divorced choke, holleys either have a manual or an electric
Old Dec 5, 2009 | 04:52 AM
  #48
Matt Gruber's Avatar
Matt Gruber
with the stock 4 hole manifold u dont need the thick gasket. just a thin 4 hole gasket and your old stainless steel on top of it. u'd be set for the winter.
I dont know anything about the choke. none of my 4165 have a choke - all removed by PO.
The reason i dont like reman qjets is i'v read lars' reports about how they butcher them. In fact, a used correct bowl from your buddy for $50 or less would likely be a better buy than $200+ for a mystery reman.
Old Dec 5, 2009 | 04:59 AM
  #49
EAGAR1's Avatar
EAGAR1
I am not sure if the stock out of the box spreadbore holleys have the kit for the quick change VS springs, but if not, its worth puting on, along with the site plugs for the fuel bowl level, and they now make a kit called an adjust-a jet, which makes adjustment of the jets as easy as turning a screw, so you can hook up a stoich, fuel air gauge and dial it in perfect.
Old Dec 5, 2009 | 08:13 AM
  #50
Matt Gruber
this is why i'm pounding on the table
with the 4165 YOU DONT NEED TO DO THAT CRAP
1. NO VS - so no stupid spring to fiddle with
2. the primarys are properly jetted for chevy V8's, as long as yours has at least 12" vacuum at idle, at or lower than 800 rpm. By proper i mean with a stick, a 350 should get 17-20 mpg at cruise, and a stock BB about 14-16 mpg, if they have a fully separated dual plane.
Site plugs? not needed, once it is set right, it will stay there.
Old Dec 5, 2009 | 08:23 AM
  #51
71coupe454's Avatar
71coupe454
This says it is divorced choke.. is this what I need for my stock choke set-up?
http://www.summitracing.com/search/P...5&autoview=SKU
Holley 0-6210 - Holley Model 4165 Carburetors
View Image and Compare
Compare
Carburetor, Model 4165, 650 cfm, Spread Bore, Divorced Choke, 4-Barrel, Single Inlet, Silver, Chevy, Each
Part Number: HLY-0-6210
Estimated Ship Date: 12/7/20
Old Dec 6, 2009 | 10:41 AM
  #52
71coupe454's Avatar
71coupe454
I have the carb and stainless steel gasket in my cart ready to buy at summit . What are you guys doing for a fuel line from pump to carb? When I search summit fot "fuel line" all I get is duel feed lines and braided hoses, I just want a simple steel line to replace the rubber hose and glass filter I have now. Also I'd like confirmation that "devorced choke" is the coil type with the tin box over it mounted to/in the intake? I still might have a fix for my q-jet, found 5 bowles if any of them match mine and will work...Thanks
Old Dec 6, 2009 | 10:53 AM
  #53
Golden's Avatar
Golden
I don't understand how you can say it's perfect out the box and jetted for 'chevy V8's' with all the engine variations over the years and states?
How can one carb be perfect for every application 'out the box'?
Old Dec 6, 2009 | 01:46 PM
  #54
EAGAR1's Avatar
EAGAR1
Well Golden I understand Matt's passion, but what I have found is that you never leave anything static, constant changes to accessories, adding headers, etc., or even saving the carb when you sell the vehicle, makes having a tuneable platform nice because you can keep that carb for future projects etc.
Old Dec 6, 2009 | 03:06 PM
  #55
Matt Gruber
Holly programmed it for the 1970 350 vette. It just happens to work great on others.
It is just a device for mixing fuel wth air. It worked great on my 283 and 350's, and capevettes 427 BB.
I've never seen anyone with 12" vacuum or better and an 800 or lower idle complain about it. Actually almost no one has complained period. So if is not perfect, i don't know what set up is. Maybe i'm over-selling it? Well, i tried oxygen sensor tuning and could not improve on the factory primary jetting. i get 18-19mpg around town if i go with the flow of traffic, no tire smoke.
I've changed cams, heads, intakes, mufflers, it maintains proper mixture with the new combo, unless u allow the high plane to mix with the low plane. That will screw things up. I don't care what else you throw at it, if it idles w/ 12" or better, it knows what to do. Minor adjustments are made with the idle mixture screws. Guys just buy the wrong carb because it gives 10 hp more at 6000. So they give up idle to 5500 for 10 hp at 6000. Then one day they notice bad mpg and then want EFI. Cars in the 60's got 18 mpg on average. EFI is an emmision control device. There was nothing wrong with a proper set up carb. except emmissions
Old Dec 6, 2009 | 03:37 PM
  #56
nitronick's Avatar
nitronick
Yes Pat, the coil with the tin cover is the divorced choke.
You will probably want to go back with the same type of fuel line setup, ie: one with the positive, inline type fuel filter. The filter on those Holleys are the same as the Quadrajet, spring loaded. After a while of doing their job, they get loaded up with the normal crap from the tank, and fuel pressure will unload the spring and let all of the crap blow past. It would be a good idea to get a steel line to the filter though...
Get me some numbers and I will tell you if any of those bowls will work with your carb.
Old Dec 6, 2009 | 09:17 PM
  #57
71coupe454's Avatar
71coupe454
Got my new holley on the way now from summit. I didnt get out to the garage yet to get any numbers for my q-jet parts but I am going to try and salvage that carb to. When I put the new carb on I'd like to improve on my fuel line if possible. Pic below of how I had it just to run on the stand. I have the lower part of the steel line off the fuel pump and up just pass the top of the pump. Any suggestions?
To Best Carb suggestions?
Old Dec 7, 2009 | 04:59 AM
  #58
nitronick's Avatar
nitronick
It looks to have a steel line from the pump to the filter. I would go ahead and make a steel one from the carb to the filter, just having two small rubber pieces to connect the filter.
Old Dec 7, 2009 | 07:17 AM
  #59
71coupe454's Avatar
71coupe454
I thought I would do that but all I could find at Auto Zone that had a fitting that would screw into the carb was just a 3" straight tube. I need like a foot long piece. I saw a complete pump to carb factory type line on wilcox site but it said "except holley" Is the 4165 fitting different than a Q-jet or is it just that its bent a little different? Can you put a filter inline between the frame line and the fuel pump and have a solid line from pump to carb?
Old Dec 7, 2009 | 08:05 AM
  #60
Matt Gruber
call holley. IIRC the 4165 is a direct swap for qjet so stock line should fit.
