700r help?
Old Dec 2, 2009 | 02:01 PM
xemilliox's Avatar
xemilliox
Default 700r help?
I have found a 700r tranny out of a 89 s10. I have a 78 vette and I was wondering if anyone knows if the bellhouseing bolt pattern is different since the s10 was a v-6. I am dropping it behind the 350 that has been stroked to a 383. Thanks
Old Dec 2, 2009 | 02:11 PM
mrvette's Avatar
mrvette
IF the 6 cyl was a 4.3, which is nothing but a 350 minus 2 cyl...you are fine, BUT the S10's also came with other/smaller V6 that will not work....
2.8-3.x is a no go...
Old Dec 2, 2009 | 10:22 PM
Silent One's Avatar
Silent One
Default Use V8 internals on rebuild...
Even if it was behind a 4.3, you will still have less friction material in the clutch packs, smaller servos, etc. that will cause a short life behind any stock V8 let alone a built motor.
Old Dec 2, 2009 | 10:32 PM
forvicjr's Avatar
forvicjr
Install a hard parts rebuild kit for a 88 vette, the forward shifts are controled hydrolicly instead of using solinoids.
(Edit) Man it must be late my spelling sux!!!
To 700r help?
