Dash lights
Old Dec 6, 2009 | 08:09 PM
Brown78's Avatar
Brown78
Default Dash lights
Dash lights went out. Everything else works. Courtesy, floor and dome lights work fine. Head and parking lights are fine. The switch is only 1,2 years old. Other than changing the switch. Does anyone have other ideas??
Old Dec 6, 2009 | 08:24 PM
...Roger...'s Avatar
...Roger...
First check the inst fuse,then check to see if the fuse is hot when the switch is on, then apply 12v to the fuse and see if the lights light up
Old Dec 7, 2009 | 03:49 AM
thegavel's Avatar
thegavel
I agree!
I just spent most of the day under the dash chasing a faulty ground (got my head stuck under there & had to remove steering wheel-luckily I had the right size allen wrench or I'd still be there LOL)
It turned out to be the fuse !!!!! I checked it with a test light and meter and it "passed", BUT I found that the metal part had broken away from the glass bit.
Cheers
Gav (anyone know a good chiropractor ???? LOL)
Old Dec 7, 2009 | 09:05 AM
7T1vette's Avatar
7T1vette
If the fuse is still OK, then use a piece of wire to act as temporary ground from the metal gauge bezel to a known-good ground point. Turn on the lights and connect the ground 'jumper'. If the lights work, then you need to fix the 'bad' ground...or just hook a 'bypass' jumper to ground behind the dash so it is out-of-sight. Any way you can re-establish a good ground should work if that turns out to be the problem.
Old Dec 7, 2009 | 09:22 AM
joewill's Avatar
joewill
yes.. you could pull a bulb, ground it and see if it works, or test for 12 volts.. might be a bad ground.. these dashes have a common ground..
To Dash lights
