Mass production of GM parts vs. low-volume for other aluminum blocks. With any 'luck', the lower cost of the GM alum. blocks will drive the [excessive] price down on the other aftermarket blocks.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
My experience has been that the (non-LSx) aluminum engines are cast and/or machined by outside shops. My guess is that there are not as many automated machining processes done at the small shops (meaning higher final costs), versus the high volume (and lower cost) machining capability of the GM engine plants.
Actually quite a bit more machining. The aftermarket big inches and racing engines are built to handle superchargers and Nitro loads that hydrometer up to 100%...and they live.... some have massive girdles keeping the cranks inside the blocks...producing horsepower that is almost off the scales to go as fast as they do..[ie] 320 mph and 4 seconds for only 1000 feet.....there almost bullet proof
Point is that the Lsx block is now affordable and plenty strong enough for a 'stout' street engine. At that price and the GM block's availability, that will cut into the other block builder's pocketbooks. If their sales drop because of it, they will have to cut price to stay in business. All good news for the consumer.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My buddy has a big pile of these aluminum LSx blocks in the corner of his shop. As Gkull said they can handle up to about 500HP past that it's a crap shoot ( I don't give a rats azz if you have a 600hP LS motor in your C5 and it hasn't blown up.....yet ) . They put blowers and nitrous on them and they blow up.
The aluminum Gen 1 blocks are made for more HP so they cost more
My comment was about the amount of (less expensive) automated machining, not the total amount of machining. If there's less automated machining done, then that means more "human controlled" machining is required, with an accompaning increase in price due to the labor hours cost.
You are absolutely correct. And your point is....that their costs/expenses are higher? Which means their product costs more? Which means they are not as competitive with "the low-priced spread".
Folks can talk about the [actual] differences in block design and strength all day long. The fact is that people buy less expensive products to save money over something that they perceive is a similar product. Why else would C3 owners buy inexpensive Chinese junk to put on their vehicle rather than high-quality [and higher cost] goods that are made well? Ans: Because they don't see any difference...hence, there is no difference. Buyers buy what they buy for lots of reasons, and a BIG one is MONEY!
http://www.gmpartsdirect.com/perform...CATID=628.html
These can be had for under $5000. They are rated to 800 HP, 5-4bolt caps, (accepts factory oil pan?), pre 1986 2 pc rear main, priority main oiling, dry sump capability, accept factory roller and spyder, accepts 3.75 crank, can be bored to 4.150 and all Gen 1 parts are a bolt on. If you machine your old block and buy a Retro roller you are about 1/2 way toward buying one of these and it won't take 800 HP. They weigh 90 Lbs. I want one. They don't produce many of these and they are not an aluminum copy of a standard 350. A lot of extra engineering and design to make this 800HP capable. This costs money. The LS blocks are mass produced.
I spent 40 years in the manufacturing arena for GM and have seen lots of block/housing machining systems. The block you see there is not machined by hand; it is finished on a CNC machine...by one guy...at one time; probably very similar to the GM block. Your block's casting cost is higher...mostly due to volume efficiency and some added cost due to the grade of material used. But....even the ineffiency of the manufacturing system doesn't account for the cost overage for those "high-priced" blocks. The reason they are so expensive is that there was demand for lightweight, high-strength, engine blocks that were available to individual buyers; but there was no availability of them. Those businesses answered that demand [good for them] and they priced their products to suck as much money as the market would bear [the American way]. Now, if the price of those 'specialty' blocks goes down over the next year or so, the evidence of good ol' competition will speak.
