Rotor tolerances
Old Dec 11, 2009 | 07:31 PM
68/70Vette's Avatar
68/70Vette
When the rotor is too thin, you got to throw it away IMO.
Many years ago, I was installing new pads on a new caliper. My then wife fronted up on the scene and started giving me some static about something I've long since forgot about. I actually put one of the pads in backwards. The metal surface was facing the rotor, and the composite material was facing the caliper pistons. I drove the car for quite a while. There was a brake squeal problem when I used the brakes. I just ignored it thinking it was just one of those disk brake things. For street and freeway driving I never had a brake concern, other than the squeal. I eventually checked out the rotor. I was amazed at the significant groves that the had been cut into the rotor. Of course the rotor was history, but the braking performance of that wheel was always 100% - of course I'm talking street performance.
I think the conclusion here is that groves in the rotor and also corresponding surfaces on the brake pad material can still result in a functional caliper/rotor brake system for street use. Obviously, as soon as you realize the groves are there you've got to get rid of the rotor and brake pads.
Old Dec 12, 2009 | 11:20 PM
drwet's Avatar
drwet
Maximum runout for Corvette rotors when mounted is .001". Otherwise the pulsing of the caliper pistons can cause them to suck air past the seals.
Old Dec 12, 2009 | 11:32 PM
7T1vette's Avatar
7T1vette
I was under the impression that all disc brake rotors needed to have .002-.003" runout to keep the pads from 'riding' the rotors and having premature wear.
Old Dec 13, 2009 | 09:59 PM
drwet's Avatar
drwet
Yeah, I've heard that too, but the General still says .001" runout on Corvette rotors. Something about the 4 piston caliper no doubt. I can also report from experience that much more than this and you end up with air in the system.
Old Dec 14, 2009 | 12:49 AM
Mike Ward's Avatar
Mike Ward
Doesn't apply to C2/C3 Corvettes, or any car with fixed caliper design.
Old Dec 14, 2009 | 01:02 PM
FB007's Avatar
FB007
Originally Posted by Mike Ward
Final installed runout as mounted on the car should be less than .003" especially on the rear.
And the significance of the rears is...........?
Old Dec 14, 2009 | 04:25 PM
Mike Ward's Avatar
Mike Ward
There's a 'double whammy' of rotor runout PLUS wheel bearing play. Almost guarantees problems with air being sucked into the calipers.
