1968 390HP Big Block
Old Dec 10, 2009 | 08:44 AM
irfgt's Avatar
irfgt
Default 1968 390HP Big Block
Does anyone have one of these and if original can you take a picture of the Choke linkage, choke thermostat, cover and rod area and post the picture? Thank you.
Old Dec 10, 2009 | 08:55 AM
7T1vette's Avatar
7T1vette
The Assembly Instruction Manual for 1968 should have detailed drawings of that linkage hook-up. But you must realize that 1968 was the initial year of C3 production and a lot of minor changes happened throughout the model year. It would be best to get a photo of an 'original' condition car near the same serial number [and build date] as yours to have any confidence that it is how your car came from the factory. But, the construction shown in the A.I.M. should suffice for judging purposes.
Old Dec 11, 2009 | 04:10 PM
irfgt's Avatar
irfgt
There is not a picture in the assembly manual. TTT Anyone?
Old Dec 11, 2009 | 10:11 PM
not a '76's Avatar
not a '76
Does this help? its a '69(ish):
http://www.pbase.com/740weapon/image/120200243
Old Dec 12, 2009 | 06:07 AM
irfgt's Avatar
irfgt
That is a huge help. Thank you so much!
Old Dec 12, 2009 | 10:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
UPC 6 C1 The L-36 section has a note that the big block assembles same as production. The L-36 choke should be the same as the small block.
To 1968 390HP Big Block
