1970 Engine ID Code question
Old Dec 11, 2009 | 05:11 PM
taz7nads's Avatar
taz7nads
Default 1970 Engine ID Code question
the engine id codes for 1970 include these two:
CRI-454, LS5, 390HP Rochester Qjet, Hydraulic Lifters, T/I, 4 speed
CZU-454, LS5, 390HP Rochester Qjet, Hydraulic Lifters, 4 speed
trying to figure out which one I have, but don't know what the "T/I" designates.
Old Dec 11, 2009 | 05:21 PM
GREGG-73's Avatar
GREGG-73
Transistor Ignition.....
Old Dec 11, 2009 | 05:45 PM
taz7nads's Avatar
taz7nads
how would I know if I have/had one? the factory distributor has been replaced with a Mallory dual point, so is there anyway to tell other than finding the engine code itself? If not, where might the engine code be hiding? Thanks to you guys here, I'm slowly but surely learning more about what I've got........
Old Dec 11, 2009 | 05:57 PM
GREGG-73's Avatar
GREGG-73
See the below thread....or search all the threads on the site....
http://forums.corvetteforum.com/c3-g...odes-help.html
Old Dec 12, 2009 | 08:22 AM
Alan 71's Avatar
Alan 71
Hi Taz,
As Gregg said you're looking for the engine 3 letter suffix code It's stamped on the flat pad in front of the passenger's side head.This picture is of a small block engine but you'll see something similar. (the 2 groups will be reversed in position)
Good Luck!
Regards,
Alan
Old Dec 12, 2009 | 11:41 AM
joewill's Avatar
joewill
they did not make a CRI did they? even though it is published?
Old Dec 12, 2009 | 12:00 PM
Solid LT1's Avatar
Solid LT1
Look up ahead of the radiator support on drivers side, the amplifier was mounted on the inner fender panel. Here is a quick shot of the K-66 Transistor Ignition Amplifier on my 70 LT-1
To 1970 Engine ID Code question
