Lights don't close together.
Old Dec 13, 2009 | 10:13 AM
pshiffer's Avatar
pshiffer
Navigator
Default Lights don't close together.
Hi,
Newbie question. Have a 1981 vette where the lights open together, but when closing, one closes before the other. Is this 'normal' or should I be looking for a problem to fix?
Thanks,
Shiff
Old Dec 13, 2009 | 11:50 AM
7T1vette's Avatar
7T1vette
That is indicative that there is some wearing of the actuator seals on the 'slow' one. I would consider it "normal" wear and that it only needs to be corrected when that lamp assembly is excessively slow or fails to operate effectively.
Old Dec 13, 2009 | 01:11 PM
Carlos840's Avatar
Carlos840
Hi, what exactly are the actuator seals? I hav ethe same problem on mine and always wondered what i could do... The same one also has trouble going up...
Do you have a schematic or pic of the part in question?
Thank you
Old Dec 13, 2009 | 01:52 PM
Mike Ward's Avatar
Mike Ward
A vacuum leak anywhere in the system can cause the symptom you note. Get one of the troubleshooting and functions guides and test the components one by one till the you find the guilty party(s).
Old Dec 13, 2009 | 02:28 PM
Paul L's Avatar
Paul L
If you speaking of a second or so I would not worry about it.
Old Dec 13, 2009 | 03:02 PM
Alan 71's Avatar
Alan 71
Hi P,
I agree with Paul, Mike and 7T1, a slight difference isn't too big a deal and a 'trouble shooting guide' along with a Mighty-Vac is the way to find the weak component or seal if you want look for a problem.
Regards,
Alan
Old Dec 13, 2009 | 03:19 PM
Alan 71's Avatar
Alan 71
Hi Carlos,
The 'seal' is the rubber 'boot' you see on the rod that moves in and out of the actuator. It makes the seal between the rod and actuator body.
There was a post about this seal's position on the rod in the last few days with a picture of it. Take a look back a little bit.
Regards,
Alan
Old Dec 13, 2009 | 05:18 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have always called the piece in question a "Witches hat". They are easy enough to change if you have the headlight actuators out of the car. You can buy them individually or you can buy a kit that comes with the metal clamp that holds the seal in place.
Old Dec 13, 2009 | 05:20 PM
Carlos840's Avatar
Carlos840
Thanks a lot guys...
Old Dec 15, 2009 | 08:43 PM
Eddie 70's Avatar
Eddie 70
Here are the links to the above parts. These should help you along with getting the headlights working together again.
For the Witches Hat with the retainer.
For just the Witches Hat.
Old Dec 15, 2009 | 10:14 PM
veronicas dad's Avatar
veronicas dad
i have a '76 and my lights open AND close seperatly, it's still a vacuum problem right? or is that a symptom of something else?
Old Dec 15, 2009 | 10:18 PM
Mike Ward's Avatar
Mike Ward
Those pieces cause the actuator to OPEN the lights. The OP has a problem CLOSING the lights. As suggested before, do basic troubleshooting before randomly changing components.
Old Dec 15, 2009 | 11:31 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I think mine went up and down at the same time about the last time my parking brake worked, around 1981, forgeddaboudit
Old Dec 16, 2009 | 12:37 AM
SH-60B's Avatar
SH-60B
It's an idiosyncrasy of the car and I don't see anything wrong with mine doing it. I'll fix them if they stop working all together.
Old Dec 16, 2009 | 11:57 AM
MotorHead's Avatar
MotorHead
I replaced almost everything with new stuff and they still don't go up and down in unison, but they go up and down now so I am happy
Old Dec 16, 2009 | 12:17 PM
...Roger...'s Avatar
...Roger...
Some go up and down close to the same time but there are cars that don't even though everything is in good shape.
I think the reason GM went to 2 relays was to try to bring them closer together. The best way I have found to match them up is to put resistance into the system in the mechanism and then if needed restrict the vacuum flow.
Old Dec 16, 2009 | 12:18 PM
Peterbuilt's Avatar
Peterbuilt
Default Here's a troubleshooting guide.
http://www.corvette-101.com/vacuum.htm The text is good but the diagram is not correct.
To Lights don't close together.
Old Dec 16, 2009 | 12:29 PM
...Roger...
Wonder how we could get that diagram changed ?
Old Dec 16, 2009 | 12:36 PM
Peterbuilt's Avatar
Peterbuilt
I don't think we can change it, just go to Willcox's help section for a good diagram or use this if you own a 74.
Old Feb 6, 2010 | 08:29 AM
vmaquera's Avatar
vmaquera
Default lights don't close together
Vacuum problems with the lights seem to be a common problem. A solution has been to use electric motors. I haven't done it, but here is an article on how to do it:
http://mcspeed.homestead.com/Our_Products.html
Ecklers also sells a kit to do this:
http://www.ecklers.com/product.asp?p...7&dept_id=1381
Next time I have headlight trouble, I will like try this out....
