Wiper Door Question
I think all other vacuum hoses are correct per Wilcoxx diagram.
Any other ideas as to what is causing this?
"ANY ITEM" in your system could be leaking very very slightly causing the system vac to drop low enough for the wiper door relay to relax into the "up" position. If your only issue is the door popping up and then going down I have found by restricting the yellow hose ( you can do all 3 hoses if you want) at the wiper door relay this stops the annoying up and down action of the door. It also slows the action of the door to stop that guillotine action.
(Why restrict now if the factory didn't ? I think there might be a difference in the relay springs of the repopped relays and also I think the door action is looser than when the car was new. )
I think you make an interesting point.
I was taught that the 'supply' (actuator) hoses were large and the 'control' (relay) hoses were small so that at start-up the control relays would have full vacuum (and send their 'close' signal) BEFORE the supply to the actuators would have enough vacuum to open the lights and wiper door. This was in the design to keep the doors closed even if the 'control' vacuum had leaked off while the car was sitting.
If I might ask...what do you use to restrict the yellow supply hose and where do you put it?
Regards,
Alan
I'm not sure about that way of thinking and if that was part of the design.
IMO more vacuum volume is going to flow through the larger less restricted hose.
With the smaller hose the large source of engine vacuum is going to be restricted by the small hose and charge through the larger unrestricted hose to the actuator and BOOM up it goes before the vacuum can get through the small hose and move the valve in the relay from the down position to the up position.
Another thing to consider is when the vacuum builds in the system 0-1-3-4 and so on its going to try to build through out the system the same large or small hose.
The wiper door actuator will move with about 2" of vacuum.
The control part of the valve takes about 4" of vacuum to move the valve from the open position to the close position.
Alan for a restrictor I used a piece of plastic with a 3/32 hole that I slide inside the yellow hose. (I started out restricting the green up hose but liked the softer movement so well that I moved it to the yellow so it would effect open and close.)
It's an intermittent problem which has made it a BEAR to locate.
I was intrigued with your 'band-aid fix' which would allow me to put it further down on my list.
Regards,
Alan
We all know that the system does in time leak down,no doubt about that, so it becomes all about the way the system recharges itself. I believe its a balance thing.
Maybe the vacuum flow through the new check valves has something to do with it,the originals were pretty restrictive.
too long ago now to recall just what affect that had on the headlights, but they worked 'OK" more or less, for a vacuum operated thing anyway...I used ONE vac relay up front for them....
then the wiper door, doing the popup trick, I found to cut the control relay apart, and cut some loops outta the actuation/control spring, weakening it greatly...then reseal and it worked fine then....
I went through all the vac 'diodes' and other crazy parts, and found that spring thing was the final fix....
but not really, as I now have intermittant wipers with electrical operated door on a linear actuator.....
hardly nuttin is vac operated in that car any more.....
http://forums.corvetteforum.com/c3-t...-start-up.html
I was considering troubleshooting mine, however, since I 'try' not to get caught in the rain I never use the wipers, so I kinda like that it opens/closes a little each time as it helps keep all the joints moving and prevents them from binding/siezing up...I do the same with the headlights but at least they go up and down when I want them too.
I watched that video on YouTube about the Mako Experimental car and noticed that all of the vacuum operated things moved slowly and deliberately.
cc
