We are planning on pulling the motor and starting to tear into it over the holiday weekend. I still really don't have any idea what we are going to find. It doesn't appear that the motor was ever rebuilt, but looks can be deceiving.
The compression test we did looked great, I can't for the life of me remember the numbers, I'm pretty sure they are with the rest of the cars documentation that I have.
I still haven't decided 100% that I'm going to rebuild the bottom end, I'll wait until I get things apart.
Kind of looking to get a price list together to see if I'll have to do this in stages, or if I can do it all at once.
Thanks again for your help,
-Chris
With the amount of money that I spent and the time involved, if I had the choice to do it all over again, I would purchase a crate motor.
remember you can get a Year One crate motor for $2990 that makes 400hp, has Vortec heads, decent roller cam and a warranty. Just throwing that out there as you are now getting into that $3k territory with a full rebuild. That Y1 motor would likely get you 250-275 rwhp and roller cam reliability. Save your original motor for the next owner.
Or find something out of the recycler for a 5.3/5.7/6.0LS to drop in. Throw a carb and ignition box on it and call it a day.
I had considered the crate motor route for mb a half a second, but that just takes all of the fun out of the hobby.
Thanks for the tip on the heads, I never trust anything mass produced anyway and always pull things apart for inspection/cleaning before using them (that includes computers =)
The learning experience, time spent with my father, and the pride felt after doing this task makes it all worth it.
You definitely have the right mind set for your project. I wish my sons liked wrenching on cars; that would make it all the more special. Looking forward to seeing your project. Start posting some pics . . . we like lots of pics
So what set up did you end up going with? You sound like me... Can do the work, just don't know how to pick the right parts that work together to make a great build.
Hopefully I can get the courage to finally pull the trigger on something like you did. Your engine looks good.
I went with AFR's and 1.6 full roller rockers as well. What size heads and what cam did you go with?
I didn't end up buying any of the complete kits, I pieced parts together instead. It's pretty tough to read through everyones opinions, but I think I managed (Guess I'll find out when I get to drive it). I did buy the TH350 rebuild kit from Monster Transmission (I have mixed feelings about that decision).
The weekend can't come fast enough!
I went with the AFR 180cc Street Eliminator Heads as well although I had them shaved to 60cc. I chose the XE262 from comp cams. I think you will like the setup but for some reason I thought there would be more. I have not DYNO'd it yet so until then I really won't know what improvements I've made.
Oh no don't say that! What compression ratio and rear gears are you running?
I'm at 9.6:1 with 3.55s in the rear.
I hope to have at least a bit more power than stock, but even if it didn't, at least those AFR's look AWESOME
It would be interesting to compare our dyno results.
At .462/.469 lift, the cam is leaving a fair bit of flow on the table with those heads.
Relatively mild cam + relatively large cross-section runners = poor low-speed throttle response and mushy power peak.
The XE 268 at .477/.480 is better, but still leaving flow on the table.
Buying AFR heads, which are the very best out there, means making the decision to use a cam that will take full advantage of them...otherwise just buy a lower-end head to match the cam.
That said - make sure you check the timing curve first thing, then a carb tune. Tuning makes a HUGE difference and should be part of the budget for any top or build.
What would be your recommendation on cam size? I'm definitely going to upgrade the tq converter. The timing is correct and the QJet is properly tuned by LARS...
Considering the flow of the AFRs, I'd spend the money for a retrofit roller. Not cheap...but it allows us to get into a lift range to fully exploit the capabilities of the head while still retaining good street manners.
The AFR streets deliver 260/207 CFM flow at .500...so I certainly wouldn't do anything less than that for lift. A .500 lift cam in a flat-tappet is fairly radical, but a roller hydraulic is just getting started
What trans and gears do you have? That helps with the other aspects of the cam choice. I would also call AFR and the cam vendors to get their takes...and of course a lot of smart folks here with good guidance.
