My window is actually loose- falling out but held in by the trim right now. I'm curious about this modification as a removable back window would be awesome.
What is required (besides the bezels) to make this update? If my window is removed undamaged, will I need a different one, or will my window fit a repro aluminum frame?
Is there one source that you can buy everything needed for this mod, or do you have to search ebay and craigslist for the parts? Where is the best place to get the parts?
I had to source ebay for the window.The bezels I bought on this site.The rear window latches weatherstripping are available thru variuos corvette houses.Now if you can't find the window I beleive a member managed to use his original window and did some modifications from Lowes to make it work, you would have to look back at old threads. Yes this is very cool and I am looking forward to spring as I doubt that I will ever have it in but I can in case I have to.
I am currently doing this mod, so far window came out easily, just used a utility knife and cut through the sealant, no problem and I'm sure it was the original stuff.
Cleaned up the opening, cleaned up the frame.
And as per usual, now I can not find the weatherstrip, so I'm hunting for. it. Usually for me the only way to find it is to buy another one.
i used aluminum c channel and notched the sides with a cut wheel in the areas that bent around the curves. i measured to the centers where the pins at the bottom of window would go and drilled holes . i used aluminum rivets with the pins pulled out and ground opposite sides of the head so it would fit into channel i filled channel with black urethane and set window in with toothpics on both sides of window to center. clamped and let dry. it gave my window a rigid feel. once dry i trimmed excess urethane and sanded the channel smooth along all the notches and finally painted. it turned out great and made the window rigid. it was a very easy and inexpensive mod
Reason: add pics
I've got all the parts and am about ready to start. I got the old window out without breaking it. One question? What is best to use to remove the old weather stripping?
Which interior bezel are you talking about, I'm not familiar with that part ???
You can keep an eye on ebay, there have been complete sets for around $400.
I bought parts here and there and have finally got around to the install. Right now I'm waiting on the weather strip, I thought I had one but can't find it.
I used a razor blade and slowly went around, came off no problem. I did put paper down underneath to keep the shrapnel out of the carpet.
I then cleaned around it with pre-clean, now waiting on the weatherstrip, hopefully installed over the weekend.
I won that auction, and you're right, it was a great deal. Everything is in great condition. I just have to clean off the old weather stripping from the window frame and I'm ready to install, however, time to do it is the problem. I'm also installing a Vintage Air Gen IV A/C in my car and that's taking up alot of my spare time.
Of all of the things that I have done on my car in the last 33 years I would rate this on a scale of 1-10. 10 being the hardest I would say it's a " 3 " if you have all of the parts ,than its just a matter of removing the rear window and installing the new parts. All of the holes are already manufactured into the car so alignment is not going to be an issue. The hardest part that I seemed to have ( only because I did not have an extra set of hands ,was installing the new gastet. Other than that everything is just bolt on. I used reproduction latches and they work great , no need to go NOS ,it just adds to the cost , spend the money on a good glass and frame and you won't be sorry.
Hey guys , want to know what was a " 10 " ???? !!!!!
YUP,#4 body mount , a word to the wise keep the ones that you have cleaned out so they don't rot out like mine did. Had I realized what was happening to mine I would have drilled weep hole in them for drainage, mine were packed with mud and salt I never thought to flush them out when washing the car, I DO NOW!!!!
how did you attach the body mount reinforcement at the back?? any pics?
For all the Corvette owners that are installing the removeable rear window feature in their Corvette, there are different halo panels for different years that had this feature.
'68 & '69 halo panels had a cut out that used a metal bezel for a finished look. '70 panels had a built-in stepped ledge in the cut out to give a finished look and used 2 black screws at the rear cut out edge for attachment points. '71 panels had the same style cut out with only 1 screw for attachment point. '72 panels had same style cut out with NO screw used in the cut out area for attachment.
If you use a '68 or '69 halo panel or cut out the latch area in a halo panel NOT made for this feature, you WILL need the metal bezels for a finshed look. The metal bezels were NOT made to be used with '70 , '71 or '72 panels.
i have all the parts..the plastic guide is on the bottom and the metal guide is on top of it??? it seems the first install is the weatherstrip? then put the window in and put the latches against the frame then drill the holes to mount them? my latches came with quarter 20 screws...correct? what size screws for the guides? shheet metal screws? or machine screws? thanks guys....im sure the chrome frame is gonna look better than the plastic frame... i bet the window will be out all the time...
Yes, the plastic guide goes under the metal guide. You will need to make or obtain the plate that goes under the lip on the bottom side that reinforces the plastic & fiberglass from the bottom and acts as a nut. I made mine from 1/8" x 1-1/4" flat bar stock, and drilled and tapped it for the screws. I think they were #6 screws but I don't remember if the thread was fine thread or coarse. #8 would work fine too if you tap the bottom plate accordingly.
The upper latches should use 1/4-20 screws. You'll need something to screw them into also, I took some more flat bar stock and drilled/tapped a hole to screw into. J-nuts would work better if you found some with the right length reach, but the ones I got at the hardware store wouldn't work right.
You can install the weatherstrip last, which is a plus since you can put the window in and close the latches to hold the seal in place while the weatherstrip adhesive cures overnight. I left mine in for a few days so that it was good and dry.
I'm sure there are other ways to do it, but this is how I did mine and I'm happy with the results. My window looks much better stowed away in the storage area than the original did in place!
