Removable rear window conversion
Old Aug 3, 2010 | 08:16 PM
  #61
flaco1801's Avatar
flaco1801
thanks staley... wouldnt the j clips be sufficient for the metal and plastic guides? i haven tried the j clips for the top latches yet i was afraid they wouldnt reach the holes properly..... when u glued the weatherstripping in you glued on 2 edges? thanks, jeff
Old Aug 3, 2010 | 08:38 PM
  #62
dstaley's Avatar
dstaley
I don't know if they have J clips for #6 screws. They might be sufficient, however the single piece of steel will help reinforce the fiberglass a lot better. It might be fine, but for the small difference in the amount of work I figured GM knew what they were doing. Cars equipped with these from the factory had a single plate riveted in place where J clips would have been easier & cheaper.
I glued one surface at a time. For the first pass, I just glued in the surface that goes closest to the hole (the one that should do the sealing). After that had cured for a few days, I went back and folded the rubber back so that I could apply the glue to the surfaces that were left and finished the job.
Old Aug 3, 2010 | 08:46 PM
  #63
flaco1801's Avatar
flaco1801
ok didnt know there was a plate under the guides for extra support...good idea about gluing the hole side first...the second pass u just laid the glue in and let it contact without letting it cure? how did u keep the edge away from contacting?
Old Aug 4, 2010 | 09:41 AM
  #64
dstaley's Avatar
dstaley
I worked my way around about a foot or so at a time. As for how, it wasn't very graceful, that's for sure! They know what they're talking about when they call the adhesive glue "monkey snot".
Old Aug 4, 2010 | 11:22 AM
  #65
Kap142's Avatar
Kap142
Originally Posted by spinadog
Ah - I would love to find a storage tray for my '70....
Found mine on ebay
Old Oct 22, 2010 | 04:24 PM
  #66
dry's Avatar
dry
Originally Posted by dstaley
Can someone, please explain where this bezel goes or what it fits around? Is this for the rear window release lever?
Old Oct 22, 2010 | 05:05 PM
  #67
Alan 71's Avatar
Alan 71
Hi dry,
Yes that fits around the chrome window lock .
It was used up through about the beginning of the 71 model year. Here's the lock on my #6589 71 that didn't have the bezel.
Regards,
Alan
Old Oct 22, 2010 | 09:28 PM
  #68
RU7376vettes's Avatar
RU7376vettes
Try Keen Parts for the Bezels.
Old Oct 22, 2010 | 10:08 PM
  #69
flaco1801's Avatar
flaco1801
you really dont need the bezels...you can see the finished product without bezels on alan's car...
Old Oct 22, 2010 | 10:26 PM
  #70
mar's Avatar
mar
...seems like a good reproduction house could make a killing on this product!
Old Oct 22, 2010 | 10:44 PM
  #71
Taijutsu's Avatar
Taijutsu
Default I Need the Bezels.
I have the window, latches and gasket. I need the bezels and I believe there are some shims needed?
I have had J&D on htis and no response.
Any help out there? TIA
R
Old Oct 23, 2010 | 01:06 PM
  #72
Jennifer@KeenParts.com's Avatar
Premium Supporting Vendor
Thanks!
We should have new reproduction bezels available in a couple months. Give us a call if you need any of the other window parts.
Kevin
www.KeenParts.com
800-757-5336
Keen Parts Blog
