Building an LT1 clone?
Old Dec 23, 2009 | 01:11 PM
61toutrj's Avatar
61toutrj
Navigator
Default Building an LT1 clone?
Is it possible to build an LT1 from a 79 350ci chev block? I have a 79 chev 350 from a caprice that I would like to use in a 56 Chev Belair. Any thoughts?
Old Dec 23, 2009 | 02:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Anything is possible. Do you want only a lookalike or do you want to attempt to build an honest LT-1?
Old Dec 23, 2009 | 02:17 PM
61toutrj's Avatar
61toutrj
Navigator
Not so interested in the cosmetics of the engine as much as the performance.
Old Dec 23, 2009 | 02:41 PM
Lee H's Avatar
Lee H
Based on that, the LT1 was a good motor in it's day. With modern tech you can get way more performace than a cloned LT1. Best way is to dicuss you ideas with a local machince shop.
Old Dec 23, 2009 | 02:46 PM
Gordonm's Avatar
Gordonm
The heads are marginal compared to what is out there today. The cam is old school. Long duration short lift. More power can be made with modern cam design. I had an LT1 and got bored with it very quickly. Good in its day but better technology is here.
Old Dec 23, 2009 | 02:56 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Sounds like a perfect candidate for a 383 or 396 stroker combo. No need to stay at 350" for hauling a '56 Chevy around.
JIM
Old Dec 24, 2009 | 03:34 PM
Ironcross's Avatar
Ironcross
The 1970 engine is the best of the lot with special pink rods that are extremely hard to find and expensive to purchase if you want the real thing...in other words not all LT1`s are the same. They dropped 40 HP from 70 to 71 with 72`s even lower.....Where it went I dont know besides lower compression....I believe they even offered AC on the last ones and a possible hydraulic cam as the tach redline was a lowly 5500 rpm.....
Old Dec 24, 2009 | 04:15 PM
Gordonm's Avatar
Gordonm
The drop in HP was mainly due to the lower compression. In 72 it went down a little more due to timing for emissions. They were pretty much the same engine exept for the pistons and the head cc were changed. They never used a hyd. cam in a LT1. The red line was reduced to not throw off the AC belt. It had nothing to do with the motor being any weaker. The LT1 was a great motor in its time but technology has far exceeded early 70s design.
Old Dec 24, 2009 | 05:17 PM
Alan 71's Avatar
Alan 71
Hi,
I've thought the drop in H.P. from 71 motors to 72 motors was due to a change in rating criteria. I believe the 71 was measured at the flywheel with no accessories (gross), while the 72 was measured at the rear wheels (SAE).
Merry Christmas!
Regards,
Alan
Old Dec 24, 2009 | 05:19 PM
gkull's Avatar
gkull
The original LT1 and ZR1 1970 Vette were rated at only 375 hp. and with the rating changes over the years it would be even less today. They are nothing when compared to modern motors.
Nothing to uh and ah about.
Old Dec 24, 2009 | 07:12 PM
7T1vette's Avatar
7T1vette
If you don't have a block with 4-bolt mains, you probably don't want to build anything too stout (no over 400 hp, anyway). If you want more from a small block, you need to special machining for greater strength, forged components, etc., etc. I agree with the others: if you want lots of power and durability, put in a new crate motor that is built for that kind of power...not a 40 year-old block that put out less than 200hp.
If you just want the engine to "look" like an LT-1, have at it.
Old Dec 24, 2009 | 07:18 PM
427Hotrod's Avatar
427Hotrod
The January 2010 Hot Rod had a neat series of dyno tests where they flogged a 327/365 a 302/290, a high compression and a low compression LT-1 as well as a few Boss 302's 351CJ's etc. neat stuff!
JIM
Old Dec 24, 2009 | 07:30 PM
3JsVette's Avatar
3JsVette
If you want a motor for a Tri 5 Chevy you need to think about torque. While those cars are not that heavy they are BIG. No substitute for cubic inches. I have a '55 Nomad with a ZZ3 and while it's "nice" to drive it needs more power. You should consider building yourself at least a 383 and make it a "torque monster". It will be way more "fun" to drive. In the end you will be much happier with the performance.
Old Dec 24, 2009 | 07:31 PM
Ironcross's Avatar
Ironcross
tell that to one of the new 70-72 LT1 owners...
Old Dec 24, 2009 | 07:59 PM
gkull's Avatar
gkull
I drove and or road in a bunch of these 70's and pre 70's vettes when they were new. Back then it was the big blocks that ruled. When I was child I thought like a child also referring to the (the new 70-72 LT1 owners.)
I would be ashamed to even drive a 13.00+ C-3 Corvette. I would not show up at the drags and brag about it. I've had solid and solid roller 350 ci motors and I thought that I had something when I could do low 12's and drive it 175 mph in open road races
Then the guy with a 496 or 540 leaves you in the dust. So unless it is over 600 hp it doesn't impress me at all. I've got to road race the brand new 505 hp C-6 Z06 and it did not impress me.
Old Dec 25, 2009 | 01:05 PM
Ironcross's Avatar
Ironcross
The 70 Lt1 was not unbeatable, but it was the best of the small blocks before and after it....but a good one should be able to stand up to and face off to a warmed over Grand National..... but that also depends on who maintains the 70....Bench racing parts dont get the job done, its the competition and combination of the Vette and driver that finally determines the outcome...
Old Dec 25, 2009 | 01:48 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
The problem with building a 1970 LT1 clone is it runs on race fuel now. It was a High RPM beast in the day but that day is gone. The only reason to build that engine today is if you have a 1970 vette or camaro that had one originally.
Build a 383 or 396 stroker with good heads and a roller cam.
Seriously you can get 100 HP more and much better torque though the entire RPM range and run on pump gas.
To Building an LT1 clone?
Old Dec 25, 2009 | 02:19 PM
63mako's Avatar
63mako
JIM
Here is the link.
http://www.hotrod.com/techarticles/e...out/index.html
Old Dec 25, 2009 | 02:28 PM
Taijutsu's Avatar
Taijutsu
Default Interesting?
What would a set of AFR 195 Comp Ported w/small solid roller cam,
air gap and appropriate carb do? Can someone do a DD on this?
This could be scary fast!
Old Dec 25, 2009 | 02:29 PM
tt 383's Avatar
tt 383
The hydraulic version of the LT1 was the L46 if I'm not mistaken, and the power decrease came from 2 points less compression.
