Headlight Dimmer Switch ???
Old Dec 24, 2009 | 07:24 AM
avner's Avatar
avner
Default Headlight Dimmer Switch ???
Merry Christmas to everyone
I need information or a pic' of the reinforcement bracket of the plastic pedal that push the headlight dimmer switch, 72 vert.
It has 4 holes, 2 holes for rivets to attach reinforcement bracket to the fiberglass and the other two for screw/rivets to hold the plastic pedal to the bracket.
I need to know if to use rivets or screws to attach the plastic pedal and if there are two screws do they have weld nuts on the reinforcement bracket.
Is the plastic pedal above or under the carpet?
Avner
Old Dec 24, 2009 | 09:11 AM
Alan 71's Avatar
Alan 71
Hi A,
On my 71 there is a plate riveted to the underbody for the 2 screws that hold the dimmer switch in place.
The plastic pedal is riveted to a metal plate that is riveted to the under body. The pedal mounts, and operates under the carpet.
Merry Christmas!
Regards,
Alan
Old Dec 24, 2009 | 09:47 AM
avner's Avatar
avner
Thanks Alan
The dimmer switch I found at the 72 AIM (upc-12 B1) but I didn't found any drawing for the plastic pedal.
Avner
Old Dec 24, 2009 | 10:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Your in the wrong section of the aim.. there is a detailed picture located in UPC 1 SHEET A16.
Merry Christmas
Willcox Inc.
Old Dec 25, 2009 | 09:11 AM
Alan 71's Avatar
Alan 71
Hi Ernie,
MERRY CHRISTMAS!!!
You're good!!!
I looked and looked for that detail... I remembered it, but couldn't find it.
You know your AIM!!!!!
Regards,
Alan
Old Dec 25, 2009 | 09:14 AM
avner's Avatar
avner
Thanks Willcox
Can I make a search on the CD for example the word = 'DIMMER' and the word will show up in all the pages it written?
Merry Christmas
Avner
To Headlight Dimmer Switch ???
