Which Timing Chain?
Old Dec 26, 2009 | 04:16 PM
DO2G's Avatar
DO2G
Originally Posted by billla
That one's fine.
Other folks are going to be more help with the balancer question - I don't know the stock diameter of a '78. But this is another place where you don't need to go crazy; Pioneer is a good OEM-type brand and is resold by NAPA. You don't need a Fluidampr or something that's SFI-approved unless you're going racing or making above 1.2 HP/CID. There will certainly be other opinions, this is just mine
It's a good time to consider investing in a degreed balancer (or buy a dialback timing light), take time to verify TDC and put on an adjustable pointer. This is good prep for doing some solid tuning work per the great timing FAQ posted in this section - and making sure you get the most out of that cam swap.
More details on the cam swap would be cool, too
Needed a winter project...
http://www.summitracing.com/parts/LUN-60101LK/
Old Dec 26, 2009 | 04:28 PM
billla's Avatar
billla
St. Jude Donor '14
It's a good pick overall - cams over .450 lift a) *may* hit the stock valve covers with the stock rockers and b) *may* encounter coil bind with stock springs. Check stuff *very carefully*
Old Dec 26, 2009 | 04:47 PM
DO2G's Avatar
DO2G
Will do. Thank you
Old Dec 26, 2009 | 08:29 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Basic 3 position $25 Cloyes will work fine. I've been using them in these 7500 rpm 800+ hp bigblocks with tons of spring pressure and they hold up fine. Never had one fail yet.
Lots of advertising hype out there and these timing sets are a great profit maker. This is one of those areas where spending huge $$ doesn't gain you much if anything.
JIM
Old Dec 26, 2009 | 09:28 PM
WhiteC3's Avatar
WhiteC3
