Which Timing Chain?
Old Dec 25, 2009 | 12:48 PM
DO2G's Avatar
DO2G
Default Which Timing Chain?
Need a new timing chain set. I don't need anything to fancy. Will this one work?
http://www.summitracing.com/parts.aspx?sku=CLO-C-3023X
Or, do I need the more expensive one?
http://www.summitracing.com/parts.as...=CLO-9-3500TX9
Old Dec 25, 2009 | 01:10 PM
mds3013's Avatar
mds3013
First one is better design than stock and is what you would run for stock cam timing. I do not know about overall quality. mds...
Old Dec 25, 2009 | 01:40 PM
piperkansas's Avatar
piperkansas
I bought one of those cheap sets once. When I did a cam swap less than 10K later, it was junk (stretched). I think I'd go with the better one in your post for durability and the fact that it's made here, not China.
Old Dec 25, 2009 | 02:46 PM
jdp6000's Avatar
jdp6000
I have used both. Both are okay. I like the double roller though. It will probably last longer. You don't want to do that job twice.
Jim
Old Dec 26, 2009 | 09:47 AM
DO2G's Avatar
DO2G
Jim
I think they are both double rollers.
Old Dec 26, 2009 | 10:07 AM
jdp6000's Avatar
jdp6000
I don't understand the difference then. Other then the more expensive looks universal. The discription is more or less the same. My single roller was that gold color. I used the exact replacement. Only one slot on the crank pulley, not multiple. I'm not sure what diffrence this makes in strength if anything.
My single was just almost as thick but teeth wear solid all the way across.
Ask what the difference is. Is one a stonger metal?
FWIW I didn't change the crank pulley. It wasn't worn at all.
They call this one a no stretch http://www.ecklers.com/product.asp?p...2&dept_id=1214
Jim
Old Dec 26, 2009 | 10:19 AM
73StreetRace's Avatar
73StreetRace
The cheap one has a cast iron cam sprocket, while the other one has a steel billet cam sprocket and many adjustable positions for the woodruff key on crankshaft, allowing cam timing changes by +/-2°.
( -8, -6, -4, -2, 0°, +2, +4, +6 and +8° ).
About the chain itself, I think it's the same for both kits.
The cheapest is also probably made in Taiwan, the other is fully made in the USA and will probably last forever...
But if you only drive your vette a few thousand miles a year, or less, and if you have a mild cam, I think the Cloyes Gear C-3023X will be just fine.
Old Dec 26, 2009 | 10:49 AM
WhiteC3's Avatar
WhiteC3
I would just go with this stock type. My '81 had a double roller and was stretched pretty bad with only 10-15K miles. I went with this one : http://www.summitracing.com/parts/CLO-C-3001K/
All timing chains will stretch anyways. I'm amazed of the lack of timing chain tensioner in american V=8 engines ,seem pretty crude to me but thats the way they did it. I had a Jeep with AMC 304 I put a cam+ lifters in with new chain. After few hundred miles driving it used oil so I rebuilt the engine. I was surprised on how much stretch the chain had. When I started out it had 1/4" or little less slack after few hudred miles it had close to 7/16" slack.This is my 2 cents
I forgot to include I put the chain in link from summit in my Vette and a month later realized it had GM cam disease and had to do cam+lifters. The chain looked like the day it went in.
Old Dec 26, 2009 | 12:20 PM
gkull's Avatar
gkull
This what I use http://www.summitracing.com/parts/CRN-144984-1/
It is kind of like motorcycle helmets. If your head is not worth anything just put a $19.95 helmet on it!
Old Dec 26, 2009 | 12:35 PM
forvicjr's Avatar
forvicjr
Remember the word true roller, there is a roller and a true roller.The more expensive chain likely has solid rollers on the chain where the cheaper one has the rolled steel rollers with the seam.
Old Dec 26, 2009 | 12:55 PM
MN80Vette's Avatar
MN80Vette
I agree that all roller chains stretch whether the chain is on a V8, a bicycle, or a chain saw. The more links and the more tension, the more potential stretch.
So, what about timing gears? They can wear but they can't stretch. What are the downsides?
Old Dec 26, 2009 | 12:58 PM
billla's Avatar
billla
St. Jude Donor '14
The basic Cloyes double-roller is going to be 100% fine for anything making less than about 1.2 HP/CID. I've used these in 100+ engines with never any problems.
The difference between the two links is billet vs. cast sprockets - billet is not a consideration until over 1.2 HP/CID, nor are Torrington bearings, etc. The chain *might* be "higher quality" as well.
I'd be real careful playing with advancing/retarding the cam. This is a great way to move the power peaks down/up by about 500 RPM/2 degrees of advance/retard - but it also affect valve-to-piston clearance and has other side-effects as well. Best to install it straight up unless you know exactly what you want from the change.
Why do you need a new timing set?
Old Dec 26, 2009 | 01:22 PM
forvicjr's Avatar
forvicjr
Loss of HP due to friction and valve train harmonics.
Old Dec 26, 2009 | 02:19 PM
DO2G's Avatar
DO2G
Changing the cam and figured while I had everything apart I would put on a new timing set on.
Thoughts? Should I do something different?
Old Dec 26, 2009 | 02:27 PM
bluzman2004's Avatar
bluzman2004
A Cloyes double roller will be fine for 99% of street and street/strip builds. If you are all out racing and need or want to adjust your cam timing, get a billet one.
Remember, when you buy the Summit brand, you are buying the lowest bidder for a given part.
I can also tell you that alot of the companies that sell timing chain sets, private label Cloyes stuff.
Old Dec 26, 2009 | 02:39 PM
WhiteC3's Avatar
WhiteC3
Thats good for a race car. Keep in mind that expensive is not necessarily better. I've spent the high buck thinking I will get a better part and it turns out to not hold up any better anyway. The chain I listed earlier is fine for a street car or mild build. I like the one I used because you look at how much area is steel links verses the roller chains the one and overlap joint, but it up to the user to decide. To the friction,so minute does it really matter. Then again I only have 200 hp and happy to stop there.Any more HP will increase the chances of my vette breaking which it does too often anyways.
Old Dec 26, 2009 | 03:20 PM
billla's Avatar
billla
St. Jude Donor '14
That's exactly the right thinking
"While you're in there" inspect your balancer to ensure the elastomer ring isn't degraded, and take a look at the front cover seal.
Since you have to remove the fuel pump, it's also a good time to have a look there and see if it's time
To Which Timing Chain?
Old Dec 26, 2009 | 03:26 PM
Aggitated Monkey's Avatar
Aggitated Monkey
I think these have made good cheaters for smog requirements. I think the cloyes have been good chains. I used to like geardrive for the whine they make
Old Dec 26, 2009 | 03:35 PM
DO2G's Avatar
DO2G
So, you like this one? http://www.summitracing.com/parts.aspx?sku=CLO-C-3023X
I was also going to replace the balancer. Any suggestions?
Old Dec 26, 2009 | 04:07 PM
billla's Avatar
billla
St. Jude Donor '14
That one's fine.
Other folks are going to be more help with the balancer question - I don't know the stock diameter of a '78. But this is another place where you don't need to go crazy; Pioneer is a good OEM-type brand and is resold by NAPA. You don't need a Fluidampr or something that's SFI-approved unless you're going racing or making above 1.2 HP/CID. There will certainly be other opinions, this is just mine
It's a good time to consider investing in a degreed balancer (or buy a dialback timing light), take time to verify TDC and put on an adjustable pointer. This is good prep for doing some solid tuning work per the great timing FAQ posted in this section - and making sure you get the most out of that cam swap.
More details on the cam swap would be cool, too
