VBP smart struts
Old Dec 27, 2009 | 08:36 AM
zigvs's Avatar
zigvs
Default VBP smart struts
what the advantage with the VBP smart struts?Do they really make a difference or is it a race only thing?
Old Dec 27, 2009 | 09:35 AM
7T3C3TTZ07's Avatar
7T3C3TTZ07
The following excellent pictures were posted by another forum member and explain smart struts well. The smart strut lowers the internal link location by 1.5 inches. This results in reduced negative camber: -1.85 deg versus -2.18 deg when the trailing arm moves upward by 2" as a result of a cornering load or bump. Some road course folks express the desire for some negative camber.
Old Dec 27, 2009 | 10:29 AM
zigvs's Avatar
zigvs
I understand the alinment could be set at 0 at a satic position. it only when hard cornering?So for the street car guy its not nessesary.
Old Dec 27, 2009 | 02:43 PM
gkull's Avatar
gkull
Vette stock strut rods and ends are kind of cheesy!
I have had S.S. from VB&P for 20 years now. There is a small group of people that think that camber gain with vertical wheel travel is a good thing. Well if it is so good, why doesn't every modern race car incorporate it?
I use the poly ends
Old Dec 27, 2009 | 04:54 PM
zigvs's Avatar
zigvs
i was thinking the same thing.you would want the the camber to stay the same throughout the wheel travel.So the smart strut is not nessessary just good adjustable struts
Old Dec 27, 2009 | 05:12 PM
another-user's Avatar
another-user
i suddenly feel like a fkn idiot... if that picture is correct, ive got my SS bracket on upside down.
wait, that cant be right. if it was upside down, it wouldnt fit flush with the diff.
Old Dec 27, 2009 | 05:31 PM
corvettedave383's Avatar
corvettedave383
the pic is wrong!
Old Dec 27, 2009 | 05:35 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I agree that the amount of camber gain originally built in to the C3 is a bit too much for modern tires (the C2 was even worse), but to eliminate it altogether is IMHO throwing the baby out with the bath water, as doing so can result in having the outside rear tire lean into positive camber when the chassis rolls during hard cornering, depending on how much is the static camber. This is fundamental math inherent to suspension dynamics.
That said, it appears that the higher power output and/or wider the rear tires, the more sensitive will be a vehicle's setup to excessive camber gain. However, that's not to say avoiding camber gain should be a necessary goal of suspension tuning; rather it should be optimized to best suit the application at hand. IMCO, I'd urge caution against drawing too many conclusions from what seems to work for other vehicles (especially F1, where many compromises are made in the name of aerodynamics), and I'd add that drag racing is really the only place where one should consider camber gain verboten.
So, I stand behind my long held view that John Greenwood's advice to lower the inner camber strut links to 1/2" below the C3's OEM height as being sound for anyone not able to prove out a better setting for their own vehicle thru testing. With VB&P's Smart Strut bracket (available separately, #52000B IIRC), that's just about at the top of the "inclination" slot. But, given that there's no one setup that best works for every driver/car combo, by all means play with different settings if you wish. That's one of the great things about having easily adjustable camber curves. Just be wary that it's just as easy to go astray...
TSW
Old Dec 27, 2009 | 05:37 PM
WESCH's Avatar
WESCH
Hi
The camber does stay more equal with the smart struts because the lowered center bracket of the strut rods makes the strut rod run more parallel with the drive shaft.
The original design, is it with the rigit strut rods or with adjustable strut rods, does change the camber when the wheel moves up & down.
If you have larger tires that hardly make it past the fender, you may want some camber change in order to make the tire pass the fender when the wheel moves all the way up.
If I install the smart strut system on my 68 with the 275 tires, the fender will be gone at the next bump.
Rgds. Günther
Old Dec 27, 2009 | 05:44 PM
zigvs's Avatar
zigvs
aaahhh makes perfect sense WESCH.
Old Dec 27, 2009 | 10:46 PM
Bee Jay's Avatar
Bee Jay
Even Chevy realized that the strut mount should be lower. The top bracket is early Vette, the lower bracket is my stock '79 Vette bracket. The second picture is the bracket I'm using now. Almost zero camber change thru the range of travel.
Bee Jay
Old Dec 27, 2009 | 11:02 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I am in the process of installing Van Steel version of smart struts. The setup I have does move the inner mounting point down but it also allows it to be moved up and down using the eccentric. My question is should I put the eccentric at the bottom, lowering the inner mount or should it be put near the midpoint. The struts themselves are adjustable too to get the camber back to where I found it.
Old Dec 27, 2009 | 11:08 PM
TheSkunkWorks
Eddie, I spoke to that in my previous post.
...and FWIW, Bee Jay's shot of the two OEM brackets illustrates what I mentioned in my comment about the C2 having been worse than the C3...
Old Dec 27, 2009 | 11:17 PM
Eddie 70's Avatar
Eddie 70
I shot the comparison shot of the two brackets when I got my stocker out this afternoon. There is quite a difference in the two. One thing I do like is the Van Steel version is quite a bit heavier construction than stock. It is flat like Bee Jays and does not curve up on the ends. I have the car on jack stands and will see what happens with the curve tomorrow on your suggestion. My original plan was, I just going to set the car at ride height and get the camber back to where I found it.
Old Dec 28, 2009 | 12:15 AM
gkull's Avatar
gkull
Originally Posted by Bee Jay
Even Chevy realized that the strut mount should be lower. The top bracket is early Vette, the lower bracket is my stock '79 Vette bracket. The second picture is the bracket I'm using now. Almost zero camber change thru the range of travell.
Bee Jay
BJ, I also have a 79. When I installed the S.S. It came with an excentric to raise and lower the inner mount point. I don't have my original 79 bracket, but I would almost swear the VB&P piece even in it's highest position was lower than stock.
Eddie 70, Mine is near the bottom, but not all the way down. I have managed to get nearly even tire ware on the rear on my big slicks. Changes show up very fast on tires that ware out in a hour or two of track time.
Old Dec 28, 2009 | 07:12 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
You'll probably have to play with the camber setting to get it best for you. Gkull with his wide tires needs a very small camber gain to see even tire wear. On my car with only 235 wide 50 series tires, I am using VBP S.S. set at the very top to get the most camber gain. With this setting on fairly skinny tires, I have gotten very even tire wear and use all the tread of the rear tires during trips to the track (including the little bit of tread on the side wall). Also from what I have read and some discussions with suspension guys, it seams that the larger the rear tires & stiffer the tire sidewalls, the less camber gain you need.
Old Dec 28, 2009 | 05:16 PM
TheSkunkWorks
Results can and will vary given the specific application in question.
As I mentioned earlier, the VB&P SS bracket's top most setting is ~1/2" below the OEM C3 height. Don't know about VS's bracket, but I'm sure it is just as easily measured. Here's the business end of the VB&P...
Either piece is sturdier than the OEM ones, but I'd check whether or not you need to bush down around the mounting bolt holes as illustrated...
To VBP smart struts
Old Dec 28, 2009 | 08:25 PM
Old Veter's Avatar
Old Veter
Default smart struts
I recently went from sidepipes to undercar exhaust on my C2, and I had to remove my SS bracket because it made the exhaust pipe way to low. Don't know if that would affect you or not
Old Dec 28, 2009 | 09:01 PM
Eddie 70's Avatar
Eddie 70
I have everything back together with the exception of the lower shock mount and the spring bolts. I can move the trailing arm from the bottom all the way to the bump stop by hand. I am using a digital angle finder and measuring off the hub.
On the drivers side
Full droop 89.8
Mid point 89.6
Bump Stop 88.8
On the passengers side
Full Droop 89.4
Mid Point 89.8
Bump Stop 88.8
I have yet to put the wheels on the car and compare to my as found measurements off the wheel at ride height.
Do these numbers sound good for a driver?
Old Dec 28, 2009 | 09:48 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
On the drivers side
Full droop 89.8
Mid point 89.6
Bump Stop 88.8
Full Droop 89.4
Mid Point 89.8
Bump Stop 88.8
For drag racing this sounds fine, but it looks like the first time you encounter a corner your tires are going to go positive camber unless you've got a lot of roll stiffness.
