Sound deadener...
Old Dec 27, 2009 | 04:05 PM
S&S_ShovelHead's Avatar
S&S_ShovelHead
Default Sound deadener...
I'm restoring the interior of my 74 right now. I pulled up the old carpet and noticed there was no underlay/sound deadener. I'm not sure if they came with some and it was removed but do you guys use it? Also I was looking for some suggestions on where I could find a good deal on a new carpet set? And also did you paint the floor where replacing carpet, if so what paint did you use?
Old Dec 27, 2009 | 05:12 PM
oldsarge's Avatar
oldsarge
The floor deadener was used, I replaced mine with the new heat barrier kit. It is alot easier to use and keeps things alot cooler at the floor. I did not paint my floor, but that is your choice, as I am sure some do. The carpets and heat shields are available everywhere, you would just have to decide who you want to use.
Old Dec 27, 2009 | 06:03 PM
tarheeljww's Avatar
tarheeljww
In the process now.......first I painted two coats of sound deading paint, then hushmat on top with two layers on firewall.......
Goodluck.
Jw
Old Dec 27, 2009 | 08:44 PM
riggs 74's Avatar
riggs 74
I used Dynamat extrema on mine before I installed the carpet
set that I bought from Wilcox, I also did not paint the floor I
only made sure that it was clean. The floor Is fiberglass so its
not like its going to rust.
hope this helps,
Riggs.
Old Dec 27, 2009 | 09:07 PM
Thinpockets's Avatar
Thinpockets
I put a layer of Dynamat sound deadener down on every interior including the doors and entire rear compartment. Then a layer of Reflectix heat deadening material from Home Depot. I installed new carpet from MidAmerica that included it's own padding. The whole project resulted in much reduced noise and heat. I can now drive my 72 coupe in the Florida summer heat without the AC. Plugging a couple of holes in the firewall didn't hurt either.
This project was worth every penny and every hour it took.
Also I didn't do anything to the floor before starting except vacuum it.
Old Dec 27, 2009 | 09:21 PM
7T1vette's Avatar
7T1vette
Heat rejection is more important in [most] C3's than sound deadening. But you can do both if you need to. Just check out the throttle action when you get done putting all that under the accel pedal.
To Sound deadener...
