Converter recommendation.
Old Jan 4, 2010 | 12:31 AM
69VetteAngel's Avatar
69VetteAngel
Default Converter recommendation.
Sorry I am posting questions all over this forum, but I really tore into the car this winter. A little further, and I will be close to pulling the body off the frame...not what I was planning at all.
Anyway, the motor/tranny is out due to reasons posted elsewhere on the forum, and I am changing the compression and cam. The combo so far is:
350 .030" over.
9.8:1 comp.
Edelbrock RPMs cleaned up bowls and streamlined guides, gasket matched.
Edelbrock RPM intake
Holley 750 vac sec
Comp Cams Magnum 280: .480 lift, 230 dur @ .050, 110 LSA
1 3/4" block hugger headers and full 2 1/2" mandrel bent exhaust.
turbo 400 with stock converter.
stock 3.08 posi rear. (will be changed to 3.55 within the year)
With this combo, what is the stock converter stall (approx. with a small block 350)?
How much will we benefit from having a new converter for the combo?
What would you recommend for this combo.
This vette is my wife's, and will be street driven with an occasional blast down the quarter by myself for her viewing pleasure.
Thanks for the recommend's,
Greg.
Old Jan 4, 2010 | 06:01 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i could ramble on for ages about why,what if this and what if that but with the info you gave a 2500 should do nicely in my opinion .
stock converter is prob about 1200-1800.
you will benefit with the higher stall with more launch .
if you go to the 355 gears your cruise speed should put you above the stall speed which is what you want.
Old Jan 4, 2010 | 11:04 AM
airtime's Avatar
airtime
off topic a little but my mom has a 1970 396 chevelle ss. it has a strong motor but she went back with a stock converter. because of that, she now complains about it snatching when she puts it in gear. transmission and torque converter are very tight. as far as power goes, the thing is kind of slow untill the rpms get up to around 2200 rpms. the tight stall converter starts pulling at 1200 rpms and it takes awhile to buld the power. results. slow as car. will break the tires lose when it hits 2200 rpms but it's just slow to rev till then. if her car had a 2000 to 2200 stall it would be alot funner to drive and a lot quicker. plus the snatching when you put it in gear would be gone as the torque converter would not be wanting to pull right at idle.
Old Jan 4, 2010 | 11:28 AM
midyearvette's Avatar
midyearvette
Old Jan 4, 2010 | 12:30 PM
ajrothm's Avatar
ajrothm
2500-2800 should be good. That 230@.050 is gonna want some stall. Not to mention it will idle smoother in gear etc with stall. You might try the Hughes GM25. It's a decent converter and pretty cheap, not overly inefficient.
Old Jan 4, 2010 | 07:27 PM
C3 Stroker's Avatar
C3 Stroker
.....been there, and the OP would be very satisfied with a 2500 stall converter on the street.
Old Jan 4, 2010 | 08:59 PM
69VetteAngel
Thanks Guys,
I am looking into the Hughes GM25. I noticed it does not have the anti-balloon plates. Is this something that matters as mostly a street car (tracking it mayber twice a year), or is that strictly for serious HP?
Thanks again,
Greg.
Old Jan 4, 2010 | 09:32 PM
ajrothm's Avatar
ajrothm
You don't need the anti ballooning plate...If you are spraying a bunch of dope or leaving off of a transbrake then yes but....For a street car its not necessary.... I don't even have an anti ballooning plate in my custom built converter behind my 650 horse rat motor.
You'll be fine with the Hughes GM25...
You could also go with an ATI converter if you wanted to spend double the money....You could get more stall speed but be tighter around town and more efficient....These are almost 5 bills though.....over kill for what you are doing.
Old Jan 4, 2010 | 11:20 PM
69VetteAngel
Thanks very much...I will go with the Hughes GM25. Seems very reasonable for the high recommendations from many on here. It is going to be a little while before it is in and running, as I am doing the motor over with this combo, as well as wiring, floor glass repairs, etc..
I'll let you guys know how it runs in a few months, but I am sure it will be sweet.
Thanks again,
Greg.
Old Jan 5, 2010 | 07:07 AM
7T1vette's Avatar
7T1vette
All of the above recommendations were biased toward the quarter-mile speed at the strip. No one has mentioned that normal driveability of the car will be impacted significantly with a higher stall speed converter. You should really have her drive a car (it doesn't have to be a Corvette) which has a 2500-2800 rpm converter in it before you make that decision.
Old Jan 5, 2010 | 10:46 AM
airtime's Avatar
airtime
a local transmission guy recommended a turbo 350 stock torque converter for my mom's 396 chevelle. cheap and would give an additional 4 to 500 rpm stall on her turbo 400 stall.
Old Jan 8, 2010 | 12:06 AM
69VetteAngel
Thanks for all the suggestions. I received the Hughes converter today (GM25). We are looking forward to seeing how it responds with this. I think it is going to be just what the car needed. Felt a little sluggish off the line, and then started to pull real nice all the way up to around 5500.
One thing though, I noticed the mounting tabs on the hughes conv. doesn't have any threads for the bolts. Is this a standard type of thing with aftermarket converters? I bought an ARP bolt set and it came with nuts, but I would think the threaded lugs (as on the stock conv. would locate the flexplate much more solidly. The bolts are not a perfect fit in the mounting holes...there is some play, and all the power the motor makes passes through these bolts (from the flexplate to the converter), correct?
Thanks,
Greg.
Old Jan 8, 2010 | 05:47 AM
7T1vette's Avatar
7T1vette
Sounds like that unit wasn't completed at the manufacturing site. Call the vendor to ask about it. You have to be able to mount it to the flexplate somehow.
Old Jan 8, 2010 | 07:22 AM
Matt Gruber's Avatar
Matt Gruber
almost as bad as a too low stall, is early shifting.
cure:
http://community-2.webtv.net/mattgru/TH400/
Old Jan 8, 2010 | 11:32 AM
ajrothm's Avatar
ajrothm
The ARP bolt/nuts are a far superior mounting device then just having blocks welded on the converter and tapping threads in em. Most good aftermarket converters use the "ring style" mount that has only holes drilled in the ring therefore requiring bolts and nuts. However those holes do need to match the flexplate. Usually the flexplates will have 2 sets of holes drilled for differen bolt patterns on the converters. One set of the holes should line up when the snout of the converter is inserted into the pilot hole of the crank. Get the bolts/nuts in and tight and you will be fine.
Old Jan 8, 2010 | 11:56 AM
BKbroiler's Avatar
BKbroiler
When you are transferring rotating motion from one object to another, like a flywheel to a torque converter, the motion is transferred by the friction between the two surfaces. The friction is created by the tension in the bolts holding the two surfaces tightly together. As long as the bolts are tight, there is no shearing action on the bolts. Therefore the bolts don't have to fit tightly where they pass through the flywheel and the converter itself.
Lug nuts holding a wheel onto the brake rotor is the same principle.
Old Jan 8, 2010 | 12:23 PM
7T1vette's Avatar
7T1vette
To Converter recommendation.
Old Jan 8, 2010 | 07:10 PM
gingerbreadman1977
lug nuts have a 45 degree bevel that centres the nut down each stud but even so when you put a wheel on with no studs there is still no back and forth play.
On the other hand if there is excessive play in the hole on converter bolts which dont have a bevel then just tightening up the 3 of them may still cause back and forth movement and worse case sheering and is not going to hold jack S**T.
Old Jan 8, 2010 | 07:31 PM
ajrothm's Avatar
ajrothm
lug nuts have a 45 degree bevel that centres the nut down each stud.
On the other hand if there is play in the hole on converter bolts which dont have a bevel then just tightening up the 3 of them is not going to hold jack S**T.
Depends on how much "play" there is...A 3/8" bolt in a 1/2" hole, yes too much play but....the bolts are not gonna fit "tight" an any of the converters that have a "through hole" mounting pad that use nuts. As long as the converter is correctly centered in the pilot hole of the crank, the holes of the flywheel/converter line up, he will be fine. There is play in the bolts in my converter also before I tightened them...no problems. Torqued to 65 ft lbs. Like BK boiler said, its the face of the 2 surfaces sandwiched together that is holding the tension, not mounting pads shearing into the threads of the bolt....
I will say that sometimes you have to put some washers or spacers inbetween the converter mounting holes and the flexplate IF the converter is pulling out of the tranny pump too much to contact the flexplate. This time I had to add 1/8" washers to all the mounting points between the converter and flexplate so I would have to pull the converter so far out....I didn't want to chance sheering the ears off the inside of the pump. 500 miles so far with 650 hp, 3700 flash stall and no problems...and I am not easy on it...
Old Jan 9, 2010 | 12:07 AM
69VetteAngel
I understand. I will use the Arp bolts and nuts and torque them down. Makes sense to me.
How much end play should I look for at the converter to trans pump. I want to check this and put spacer shims, if required, before I button it up.
Thanks for the info,
Greg.
