So frustrate right now
I found the purple wire that goes on the starter, but it was just dangling there. The solenoid mount is on one end, and the other end has a flat female spade that was attached to a melted plastic piece. I can NOT for the life of me figure out where it goes. I've looked at wiring diagram, and assumed by the flat spade that it would attach to something. The only male spade under the hood that does not have anything attached to it is a reddish colored wire, about 8 inches away from the wiper motor. Tried hooking it to the purple wire...nothing.
I even got some alligator clips so I could quickly attach and detach wires in order to see if I could get SOME life out of it. Nothing. Fuses are all good.
I'm tired right now........and so very discouraged. Maybe it's something simple.....I mean, it has to be, but I just can't figure it out. There's power at the starter, but I just can't do anything with it. There's supposed to be a purple wire that comes off of the neutral safety switch, goes to the engine harness block, and over to the starter solenoid.....but can I find a purple wire on the block? No. Grrrrr. Here I try to undo some shoddy work with the original stuff, and am not rewarded for my efforts.
Uggghh......( sigh)
I then had one of the little jumper wires connected to the black wire (ground) which in turn went over to the stud on the body of the starter. Gave her a crank...and she actually tried to start! I cranked it a few time until I saw smoke coming from the starter side of the engine. Lo and behold...I melted the jumper wire! :o It was all sorts of melted. So I removed the jumper...still using the grounding stud on the back of the starter....and it cranked over. Only problem was.....it KEPT ON cranking, even after I turned the key off. I panicked and ripped the cable off of the battery...effectively separating it from the bubba'd top post terminal in the process.
So now I guess the issue is the grounding. Am I using the wrong place to ground this wire? Is my solenoid bad? It's just weird that it kept on cranking and cranking. The starter is a reman starter, but I know that even so, they use new solenoids. What am I doing wrong here?
The previous owner had installed a push button starter and my wiper ground was hot!
Mine is a manual and it would appear that after some work was done, the clutch switch was not connected, neither was the neutral switch on the tunnel. Because of this, you could put the key in the ignition, turn it and nothing! Bubba installed the push button as per the OP's post and it started.
I have now removed the push button starter and installed a clutch switch and now she starts with the key.
The wipers were also bubbad on mine and I think JimT has hit the nail on the head. Bubba obviously thought the wiper grond black wire should be connected to the starter Black wire not realising this was indeed Hot!
The joys of Vette wiring!
I'm really glad I'm not alone with Uncle Bubba.
Steve
