Fuel line
Old Jan 7, 2010 | 03:24 PM
RushThruLife's Avatar
RushThruLife
Default Fuel line
So I need to replace the hard line from my mechanical fuel pump to my q-jet. Can anyone tell me how long of a line I need to purchase. Napa sells hard lines in different lengths already made up to 5 feet in length. All I have to do is bend it.
Old Jan 7, 2010 | 03:39 PM
BKbroiler's Avatar
BKbroiler
You can buy an exact prebent replacement for the original line from Ecklers or Corvette Central. It fits.
Old Jan 7, 2010 | 04:09 PM
Alan 71's Avatar
Alan 71
Hi RTL,
I think it's a good idea to buy a pre-bent line too.
If you decide to make your own remember you'll need to have a tool to bend the line (without collapsing it) and also to flare the end of the line after you slide the fitting on.
Good Luck!
Regards,
Alan
Old Jan 7, 2010 | 04:48 PM
ED79's Avatar
ED79
with the above, pre-bent will alot less headache.
Ed79
Old Jan 7, 2010 | 05:00 PM
Roco71's Avatar
Roco71
Originally Posted by Alan 71
Hi RTL,
Good Luck!
Regards,
Alan
The cheap tool that is sold in the discount auto parts store for bending brake lines will not work on 3/8 line. Trust me to do it right you will end up buying the prebent in the end.
Best of luck
Scott
Old Jan 7, 2010 | 05:14 PM
redman76's Avatar
redman76
St. Jude Donor '09
In case you want to make your own. I'm getting the materials/tools together now to give it a try . . . How to build your own fuel line by Lars
Old Jan 7, 2010 | 05:50 PM
7T1vette's Avatar
7T1vette
If that's the only line you ever intend to make, forget it. The tools and line will cost more than the pre-made piece.
Old Jan 7, 2010 | 06:20 PM
eastltd's Avatar
eastltd
I made my own line. The third attempt fit awesome
Old Jan 7, 2010 | 06:35 PM
RushThruLife
Part ordered.......
Old Jan 8, 2010 | 05:10 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree with the above. The first do-it-yourself fuel line you fab is expensive when you figure in the tools and the 'learning curve' of using the tube-bending and flaring tools.
Also, the best tube bending tool, I've found, is the Imperial 180 Degree tool purchased at Sears,..about $45. The bends have zero evidence of 'collapse'; the tube stays nice and round through the bend. It's great!
Also, smart man, using steel tubing from pump to carb. Everytime I see any rubber hose between the pump and carb I cringe. Very Bubba. Very dangerous. Same fire dangers as running without an air cleaner.
Good luck!
Old Jan 12, 2010 | 01:06 PM
ANY VETTE's Avatar
ANY VETTE
What about a braided fuel line?
Old Jan 12, 2010 | 04:40 PM
willem wallace's Avatar
willem wallace
From what I have read, some of the braided line leaves a lot to be desired, quality wise. Prone to gas vapors escaping and causing strong gas odor.
Old Jan 12, 2010 | 05:06 PM
PRNDL's Avatar
PRNDL
Only reason to bend your own is if you are changing the configuration, for example using a modern inline fuel filter that requires a different from stock fitting. I had a lot of fun bending my own, but I did have to buy 3 different flaring tools before I could get it right!
Old Jan 12, 2010 | 06:11 PM
81pilot's Avatar
81pilot
I just ordered one ready to install from Corvette Central for 29 bucks already bent correctly with fittings.
edit: good job on ordering one...good call. :O)
To Fuel line
