Quadrajet choke
Old Jan 9, 2010 | 09:46 PM
wrw2497's Avatar
wrw2497
Default Quadrajet choke
Can a 1969 quad be converted to an electric choke ??
Old Jan 10, 2010 | 10:58 AM
SteveG75's Avatar
SteveG75
The kit posted above will not work. It is for a hot air choke and you have a divorced choke carb. Get in touch with Cliff Rugles (google the name) for a recommendation.
Old Jan 10, 2010 | 11:09 AM
wrw2497's Avatar
wrw2497
O K ...thanks
Old Jan 10, 2010 | 08:52 PM
lars's Avatar
lars
The only electric conversion for a divorced choke carb is the system sold by Carbs Unlimited. It bolts to the manifold in the choke coil location.
Lars
Old Jan 10, 2010 | 09:34 PM
wrw2497's Avatar
wrw2497
Default choke
Lars
thank you for the reply....I will check them out....I sent you an email earlier today....asking if you would be interested in "doing" my 1969 quadrajet 7029207...if not.. should I buy one from Carbs Unlimited...or could you recommend where to get a "good" one ...thanks,Rick
Old Jan 10, 2010 | 10:38 PM
lars's Avatar
lars
Send your carb off to Henry Olsen at Ole's Carb & Electric:
120 EL CAMINO REAL
SAN BRUNO CA 94066
650-589-7377
Lars
Old Jan 11, 2010 | 02:32 PM
Paul L's Avatar
Paul L
Lars
Lars,
I see EC-9035, electric choke thermostat and EC-8184A electric choke but for the life of me I can't see how this replaces the divorced choke? Any advice?
Old Jan 11, 2010 | 04:30 PM
Peterbuilt's Avatar
Peterbuilt
Paul74, look at CU445 (near the bottom of the page).
Old Jan 11, 2010 | 04:50 PM
1mollyd's Avatar
1mollyd
Lars
I have this electric conversion on my '69 and it works well. The only problem I had is that the mount is designed for the stock manifold which is apparently 90 degrees different from the Edelbrock Performer which I am running. I had to fab up my own mount.
Dave
Old Jan 11, 2010 | 05:38 PM
Paul L's Avatar
Paul L
Thanks Pete. That web site is not particularly intuitive but I found CU445 and ordered. My car did not work well last summer with the divorced choke. I'll try this one.
Is this the usual wiper motor hot wire hookup? I forget the colour.
Old Jan 12, 2010 | 07:23 PM
Paul L's Avatar
Paul L
So is it the yellow wire on the wiper or do I take it back to switched IGN on the fuse box?
Old Jan 12, 2010 | 07:44 PM
Peterbuilt's Avatar
Peterbuilt
Yes! The yellow wire from the wiper is 'Switched'.
Old Jan 12, 2010 | 08:03 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I put a manual choke on mine. Best thing i ever did for winter drive-ability.
Old Jan 14, 2010 | 03:21 PM
Paul L's Avatar
Paul L
Is an in-line cartridge fuse advisable? I'm thinking 15 amps with 16-gauge wire.
Old Jan 14, 2010 | 03:22 PM
Paul L's Avatar
Paul L
I don't drive October to April.
To Quadrajet choke
