Trans crossmember
Old Jan 11, 2010 | 11:05 PM
forvicjr's Avatar
forvicjr
Default Trans crossmember
There any differences between BB trans crossmember and one from a smallblock??? After installing, looking from the side the BB and 350 turbo seems lower at front of engine than it did with SB with 350 turbo.
Old Jan 12, 2010 | 08:51 AM
damoroso's Avatar
damoroso
The BB is few inches longer than the SB and that'll change where the crank pulley sites when mounted on the original mounts. BTW, I don't think I'd run a TH350 with a BBC....
Old Jan 12, 2010 | 04:17 PM
forvicjr's Avatar
forvicjr
Itl hold till I do the manual conversion. Ive played with the brackets some, and ill tell ya i didnt think it would be this easy.Think Im going to wind up building a custom trans crossmember. Juststart from sratch.
Old Jan 12, 2010 | 04:33 PM
willem wallace's Avatar
willem wallace
Default Crossmember
No difference, same piece!
Old Jan 12, 2010 | 06:31 PM
joewill's Avatar
joewill
a corvette frame is a corvette frame same if BB or SB..
Old Jan 12, 2010 | 06:43 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
I understood the only difference in C3's was fixed (welded in) trans crossmembers for clutch cars and removable trans crossmembers for automatic equipped cars.
Engine size wasn't the defining factor and please correct me if that's wrong.
Old Jan 12, 2010 | 09:30 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
You are correct. No need to modify or change crossmembers.
To Trans crossmember
