Drive shaft dent
Old Jan 16, 2010 | 04:05 PM
paulebrown's Avatar
paulebrown
Default Drive shaft dent
For years I've had a slight vibration at 55-60 MPH. Last year had complete rear suspension replaced, still had the vibration. Today, I pulled the drive shaft and found this dent on the aft end. Is that enough to cause the vibration? This is a '72.
pb
Old Jan 16, 2010 | 04:23 PM
Jeff78's Avatar
Jeff78
Yes it is you need a new driveshaft.
Old Jan 16, 2010 | 04:35 PM
flyingman21's Avatar
flyingman21
you should get your wheels ballanced too if you have not done that already.
Old Jan 16, 2010 | 04:49 PM
paulebrown's Avatar
paulebrown
The shaft was the last item looking for the vibration. New tires, careful balancing, new rear suspension...
I should have looked here first, but the other stuff needed to be done, anyway.
Thanks for the input, guys.
Now, does anyone recommend the best place to get the shaft among all the competing parts vendors?
pb
Old Jan 16, 2010 | 05:25 PM
7T1vette's Avatar
7T1vette
I would just take that shaft into a good driveshaft place and ask them to check it over and give you an estimate to refurb and rebalance it. That will likely cost less than a new driveshaft (plus you don't know how well the new one will be balanced!). If the dent doesn't look like a problem to them, leave it alone.
Old Jan 16, 2010 | 05:45 PM
bluthundr's Avatar
bluthundr
Contact Fort Wayne Clutch & Driveline @ 800-258-8243. They could tell you how much a repair would be but also build their own drive and half shafts for vettes if you need a replacement.
Old Jan 17, 2010 | 11:11 AM
alswagg's Avatar
alswagg
Yes, call Fort Wayne clutch. I have had many custom driveshafts made, even dual tubes, Al
Old Jan 17, 2010 | 12:40 PM
toddalin's Avatar
toddalin
Totally agree. If the dent isn't structural, it can be balanced out (if it's even out of balance).
Old Jan 17, 2010 | 05:36 PM
paulebrown's Avatar
paulebrown
You guys are great. Thanks for your input. Wish I'd found this forum years ago.
Somebody tell me, is it bad etiquette to ask about the best parts vendors?
pb
Old Jan 17, 2010 | 08:39 PM
7T1vette's Avatar
7T1vette
No. It's only bad etiquette to ask who are the worst vendors.
Old Jan 17, 2010 | 10:40 PM
Gale Banks 80''s Avatar
Gale Banks 80'
I'm going to say Your Driveline is bent. Probably very little. If you think about putting a Dent in one side will shorten it leaving the good side Longer. I had just about the same dent in one of the 1/2 shafts after it broke a U-Joint and I drove it to a show with no vibration. Looks like your driveling has a bunch of paint on it to. If its all on one side then thats going to throw it out of balance to.
Old Jan 18, 2010 | 08:28 AM
jnb5101's Avatar
jnb5101
two problems with your shaft. one is,of course the dent, which probably by itself wouldn't change the balance. but what it would do is bend the shaft. which leads to the second problem. there is so much corrosion on the surface the drive line tech won't be able to measure the run-out. but before you buy a new shaft(about $250) take to a shop and have them spin it to see how bad it is(take the yoke also).
as far as the vibration that you're chasing, the shaft may not be the problem. check things like cooling fan, pulleys, and the biggie-drive shaft angles.
Old Jan 18, 2010 | 08:57 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
The dent should be an easy to fix for a driveshaft shop. All they do is drill a hole in the shaft, heat up the dent and blow air into it to get the dent out, than balance it. You could always retube it with the original yokes to keep cost down too.
Old Jan 19, 2010 | 01:29 PM
auavette's Avatar
auavette
www.dennysdriveshaft.com
Look at this website.
Old Jan 20, 2010 | 01:49 PM
paulebrown's Avatar
paulebrown
FYI and thanks to all of you
Took the shaft to a place in Manchester, NH; they immediately noticed that both sides had a dent where someone had hammered the shaft to remove the U-joints (for replacement) Since I've owned the car for 38 years, I don't remember this being done, but I don't remember everything about yesterday.
Anyway, they will rebuild, repair, do what's necessary for cost less than buying a new one and fully balance. (get the slip yoke). Keeping the money local...Sorry Eckler...
Will report as to whether or not the vibration is gone.
Thanks again,
pb
To Drive shaft dent
