Run On
Old Jan 22, 2010 | 12:38 PM
Sweet's Avatar
Sweet
Default Run On
Brand New crate 383 just installed and it runs great. Starts right up, no pinging, no problems when hot, running 93 pump gas but when I go to shut it off I get a second or two of run on.
What causes this and how do I fix it.
Old Jan 22, 2010 | 12:41 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Most of the time it's because of insufficient advance timing at idle speed, and the resulting band-aid of large throttle opening. I would check these two items.
Old Jan 23, 2010 | 01:26 PM
Surfer69's Avatar
Surfer69
I would say sometimes there is nothing you can do about it and you have to live with it.
I've gone through a couple engines and they both did it off and on even with brand new engine. Look and see if it actually spins backwards. My theory is it's mainly leftover carbon or fuel vapor after a very hot shut down. I did notice when I removed my PCV system that it seemed to go away almost for good.
Old Jan 23, 2010 | 02:09 PM
slapshot 496's Avatar
slapshot 496
if your idle is set too high it can cause this also..
Old Jan 23, 2010 | 02:46 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Adjust the idle screw to close the throttle blades a little, and then add timing to compensate for the lower idle speed.
If you arent currently running vacuum advance connected to a manifold vacuum source, doing so would likely accomplish what you need.
Old Jan 23, 2010 | 03:56 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Most probable cause of this is ported vacuum to the distributor - instead hook it to full time manifold vacuum. As soon as you do this, you'll notice the engine idle speed increased because it's running more efficiently (faster), so you'll have to reduce the idle speed with the idle speed screw. Now the engine will cut off smartly when you kill the ignition.
Old Jan 23, 2010 | 04:02 PM
WhiteC3's Avatar
WhiteC3
Old Jan 24, 2010 | 11:00 AM
Sweet's Avatar
Sweet
The engine builder installed my original carburetor and distributor on the new motor. He dynode the motor before sending it to me. He said DO NOT hook up vacuum advance and he told me he welded a bead on my distributor so it would not go past 32-degrees total advance.
Old Jan 24, 2010 | 01:47 PM
larrywalk's Avatar
larrywalk
Your builder needs better education. Read the stickies on timing:
http://forums.corvetteforum.com/c3-t...long-post.html
Unmodify your distributor or get one that has a working vacuum advance.
Old Jan 24, 2010 | 02:05 PM
69427's Avatar
69427
No problem. Just add an additional couple of degrees to your initial timing, and hook up the vacuum advance. Take it out for a run and let us know how the engine reacts to the changes.
Old Jan 24, 2010 | 02:13 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yeah I agree advance the timing and lower your idle speed at the carb with idle speed screw. I don't even want to get into a vacuum advance debate
Old Jan 24, 2010 | 06:18 PM
Sweet's Avatar
Sweet
Please..... I want to know more.
I want understand why I was told not to hook up vacuum advance.
What is the debate.
Old Jan 24, 2010 | 06:57 PM
lars's Avatar
lars
Engine run-on is caused by excessive idle speed and/or excessive throttle blade opening at idle.
For factual info on timing and vacuum advance, just drop me an e-mail request for my papers on timing and vacuum advance. There's no reason for you not to run vacuum advance if you are running on the street with more than 9 inches of manifold vacuum.
Old Jan 24, 2010 | 10:27 PM
MotorHead's Avatar
MotorHead
What is the debate.
There is a vacuum advance club and no vacuum advance club. Some performance engine builders belong to the no vacuum advance club. One reason is to protect their azz against your engine coming back with detonation problems and he has to rebuild it. That is why he made sure to lock you out at 32 deg and told you not run a vacuum can.
I am in the no vacuum advance club, on a stock or near stock motor then yes I'm all for it but once you start to push the limits with pump gas and compression ratio and timing you can get into some detonation problems if you have the added vacuum advance which in some cases can advance you timing to over 52 degs.
Old Jan 25, 2010 | 02:31 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i agree with 69427 . im assuming your timing was set on around 12 initial with a crate 383 . you may need anywhere from 14-20 initial and then loc out your distributor to suit . 32 total seems a little low to me. fast burn heads work well with 34 but most other 350-383,s 36 is good.
you really need to sort it out as its damaging to your motor. just until you get it sorted leave your car in drive when you turn it off and it shouldnt run on. its a catch 22 cause thats not the best for your transmission but its better then run on in a motor.
i didnt hear what carb you are running but if its a demon then the transission slots absolutely have to be set to .020 showing.
i know your the man on here lars to most but why when you said this "Engine run-on is caused by excessive idle speed and/or excessive throttle blade opening at idle" did you not include low initial timing as a possibility because someone can have correct idle speed and correct throttle blade opening and still get run on.
Old Jan 25, 2010 | 08:59 AM
lars's Avatar
lars
Low initial timing will cause the throttle blade opening to be excessive, thus producing the run-on. The run-on is not caused directly by the timing since timing in inoperable when the ignition is off. The inadequate timing is the root cause of the excessive opening, but the opening is causing the run-on. We had a Service Bulletin on this in 1975, and the run-on solving techniques were taught at the GM Training Centers, where I taught as an instructor in the mid 70's.
Lars
Old Jan 25, 2010 | 10:16 AM
Sweet's Avatar
Sweet
The engine builder told me the timing at idle (850 to 900 RPM) is set at 10 degrees.
He said do not hook up the vacuum advance and that he welded a bead on my distributor so it would be 32 degrees at total advance.
Engine Model - 383ci
Horsepower - 420 HP
Torque - 460 Ft Lbs
Bore and Stroke - 4.030 x 3.750 Inches
Compression Ratio - 10:3
Camshaft - Hydraulic roller 224/230 535/544
Lifters - OEM style hydraulic roller
Heads - 200cc Dart Iron Eagle, 72cc chamber
Valves - Stainless steel 2.02 Intake 1.60 Exhaust
Rocker Arms - Aluminum full roller, 1.6 ratio
Ignition Timing - 32 degrees at 4,000 RPM
Vacuum at idle 10 inches
The engine builder is T&L Engines and they will not respond to any emails or phone calls I send to them.
Were do I start. Do I hook up the vacuum advance? How will the affect the bead welded for 32 degrees of total advance that the builder recommends. Is 10 degrees at idle too low? I AM SO CONFUSED!
To Run On
Old Jan 25, 2010 | 10:56 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Your engine would probably run best with 2-4 degrees more total timing than the 32 degrees that you are running right now.
If you bump your timing up 2° and then readjust your idle, that may solve the problem.
You will want to make sure to listen closely for any pinging that may occur under load, but 34° should be pretty safe.
If that doesnt work, try another 2° and listen closely again.
Telling you to run your engine at 32° total, and not to use any vac advance sounds like the builder wants a very safe tune on the car, even if it means it doesnt perform to its potential.
Old Jan 25, 2010 | 01:24 PM
Sweet's Avatar
Sweet
I want to make sure the I understand.
If at idel I am at 10 degrees and at full advance I'm at 32 degrees. I change my idle timing up 2 degrees to 12 degrees my total advance will go from 32 to 34 degrees and if I go to 14 at idle, total will go to 36. Is this correct.
Old Jan 25, 2010 | 02:20 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Thats correct.
