Lifter Noise L82 78
Old Jan 22, 2010 | 10:07 PM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
Default Lifter Noise L82 78
What possibilities? Didn't make noise until the valves were adjusted.
Old Jan 22, 2010 | 10:34 PM
Imo Apita's Avatar
Imo Apita
Hydraulic flat tappet?
Hydraulic roller?
Solid flat?
Solid roller?
Undo what you did last.......
Old Jan 22, 2010 | 11:27 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Hmmmm I wonder if, naahhh couldn't be, sorry, that's a real mystery hope you find it, others will chime in and help I'm sure
Old Jan 23, 2010 | 10:57 AM
billla's Avatar
billla
St. Jude Donor '14
If it started making noise after you adjusted the valves...then you didn't adjust the valves correctly. Not in any way trying to be a smart*zz, but as noted above the first question a mechanic asks is "what's changed?"
Old Jan 23, 2010 | 11:04 AM
7T1vette's Avatar
7T1vette
Did you let the engine warm up completely before you set the lifter adjustments?
Old Jan 23, 2010 | 11:29 AM
A GM dealer had the car for a week and a half to adjust the valves. As time goes on the lifters are noisier. They won't do anything about it saying the cam is the problem. Another mechanic that works on classic and exotic cars said the adjustment is to loose. That makes sense to me. Thanks guys By the way I ahve not seen any smart buts on here. You are all a bunch of good people with real life experiences. We all have something to gain and give. Personal opinion
Gary
Old Jan 23, 2010 | 11:43 AM
billla's Avatar
billla
St. Jude Donor '14
Good to hear you're on the path to resolution.
Sadly, there are few line mechanics around any more that know how to take care of a GEN I (or even GEN II). As a generalization it's not always true...but I've found it to be VERY common these days.
To Lifter Noise L82 78
