engine # ?
Old Jan 27, 2010 | 04:06 PM
pacrimmat's Avatar
pacrimmat
Default engine # ?
the motor in question has the number V0904TJC on the right front ledge of the block. I'm told the V means it is a 350 2barrel carb the 0904 might be date of mfr but dont know what TJC represents.
I think its out of a 1967 el camino but not sure. anyone seen a similar number? could it be a crate engine? thanx !
Old Jan 27, 2010 | 04:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by pacrimmat
...V0904TJC...
V plant code for the Flint (Michigan) engine assembly plant
0904 date engine was assembled at Flint (Sept 4th)
TJC engine identificatin suffix code for a 73-74 350CID truck block
Old Jan 27, 2010 | 04:17 PM
DZRick's Avatar
DZRick
TJC 1973 350 conv.cab - 160 hp 4 barrel carb Truck C-20 to 3500
Found the above here down towards the bottom of the list.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-7.php
To engine # ?
