engine bore
Old Jan 30, 2010 | 11:56 AM
ScottMH's Avatar
ScottMH
Default engine bore
hey guys my engine bores are 4.054 so is this considered 60 over? i am ordering new pistons and rings and i want to order the right stuff.
Old Jan 30, 2010 | 02:14 PM
ScottMH's Avatar
ScottMH
bump
Old Jan 30, 2010 | 02:22 PM
wnmech's Avatar
wnmech
Best answer in my opinion is take your block to your local machine shop and have them re mike your bore and they will tell you what size piston is best for you. I doubt they would even charge for that.
Mastr Fab's Avatar
Mastr Fab
In my experience a .060 over bore measures 4.060. I don't know what you have . where are you measuring the bore at?
Old Jan 30, 2010 | 03:15 PM
ScottMH's Avatar
ScottMH
at the top. using this
i measured it again and if i spin it in the bore eventually it reads 4.060...im prolly not doing this right at all haha.
Old Jan 30, 2010 | 05:33 PM
RU7376vettes's Avatar
RU7376vettes
I agree with Wnmech, take it to a machine shop that has a real bore gage. To get good reading, you need to check several places both radially and up and down in the bore. If is is that close to being .060" over then they may just be able to hone it to proper size for a set of new pistons. Do it right rather than having to do it over.
Old Jan 30, 2010 | 05:43 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Even if they do charge a nominal fee, they'll do it using a proper dial bore gauge for accuracy you can't get with vernier calipers. Also, IMCO it's a good idea to wait on ordering pistons until after having the bores cleaned up first. Don't be penny wise and pound foolish here.
Old Jan 30, 2010 | 06:09 PM
BLOCKMAN's Avatar
BLOCKMAN
A .060 piston requires a .060 over bore minimum. I woould say the block was not ever finished after boring.
Old Jan 30, 2010 | 08:48 PM
7T1vette's Avatar
7T1vette
You need some telescoping bore gauges. Set them properly in the bore, lock them down, and use your calipers to measure across the ends of the gauge. It would be better to use a good set of 4-5" vernier micrometers so that you can get accurate readings...top, middle, and bottom of bore at 0 and 90 degree locations. That will also get you roundness and taper for those bores.
To engine bore
