Internal or External Balance
Old Feb 2, 2010 | 10:06 AM
ScottMH's Avatar
ScottMH
Default Internal or External Balance
could you guys tell from these pictures if my motor was internal or external balance? I think its internal balance
Old Feb 2, 2010 | 10:08 AM
hugie82's Avatar
hugie82
Interal. No counter weights
Old Feb 2, 2010 | 10:09 AM
2armor's Avatar
2armor
What engine is it? 350?
Old Feb 2, 2010 | 10:11 AM
gkull's Avatar
gkull
I vote for internal. You don't see the added weights and or drilling on the Damper. Only most big blocks and 400 ci small blocks came externally balanced
Old Feb 2, 2010 | 10:53 AM
jordan89's Avatar
jordan89
Old Feb 2, 2010 | 11:40 AM
Sho'nuff's Avatar
Sho'nuff
Hammer marks??
Old Feb 2, 2010 | 11:54 AM
SH-60B's Avatar
SH-60B
From the first pic you can see from the witness mark it came off a two piece rear seal crank, so it was internally balanced.
Old Feb 2, 2010 | 03:49 PM
Timsride's Avatar
Timsride
Default balance
All 350's were internally balanced,at least the ones with 2 piece seals.Yours is internally balanced but looking at the hammer marks on front balancer,I would be more woried about the thrust bearing(rear main).
Old Feb 2, 2010 | 04:03 PM
ScottMH's Avatar
ScottMH
thanks for the input. this came off the motor im rebuilding. im smart enough to use a harmonic balancer puller/installer. so it wasnt I that hammered that on. but the rubber is in good shape so i wanted to be sure i could use it
To Internal or External Balance
