what is this? pic
Old Feb 6, 2010 | 09:08 AM
tjohn1008's Avatar
tjohn1008
Default what is this? pic
im thinkin this is a headlight buzzer.i have a late 76.the seat belt and ign. buzzer work.was this a add on by gm.i have done searches but cant find anything.the elect.schematic only shows a headlight warning light in the dash.there are2 brown wires coming out of the fuse box.this thing has 2 brown wires also and 1 red.if it is a headlight buzzer,dose anyone know how it is wired into the headlight circut.any little bit of info will help me figure this out.thanks much, tj.
Old Feb 6, 2010 | 04:21 PM
...Roger...'s Avatar
...Roger...
I went to do a search and found another of your threads,is this a different buzzer ?
http://forums.corvetteforum.com/c3-t...onnectors.html
Usually on these buzzers the double wires are so you can tap into a circuit like the Batt or the Ign for power , the single wire usually is grounded to make it buzz. So if its a headlight buzzer the single will attach somehow to the headlight circuit if its seat belts the single will attach to one of the seat switches. Hope that helps.
Old Feb 7, 2010 | 03:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Headlamp Warning Buzzer 1975-1976 pn 364079.
I'll post a pic in a second.
Willcox
Old Feb 7, 2010 | 04:43 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Willcox
Where can you get one? I've tried Wilcox, Ecklers, ZIP, Corvette Central & Mid-America...no luck.
Old Feb 11, 2010 | 04:32 PM
0Willcox Corvette
Former Vendor
vetteguy!
I'm taking a picture of this out to our shop. I'll have them check to see if we have one for you used.
Willcox
Old Feb 14, 2010 | 04:44 PM
vetteguy75's Avatar
vetteguy75
Thanks,.....any luck?
Old Feb 14, 2010 | 06:15 PM
0Willcox Corvette
Former Vendor
No, I'm sorry.. we went through box after box of used harness's trying to find one. No luck.
Willcox
To what is this? pic
