T top Question
Old Feb 7, 2010 | 10:53 AM
manofsteel1's Avatar
manofsteel1
Default T top Question
Getting ready to finally paint my '73 to a beautiful yellow. Was originally that mustard gold color and now a "Earl Scheib Special Paint Job Red". Yuck! Anyway, my question is concerning the T Top area. Just behind the T Top there is a valley (after the chrome trim) and I want to know what is filled in there. Kind of think that originally there was some kind of sealant. Do any one know? Would like to make sure I put the correct stuff there if there is. Have any pictures woud be appreciated.
Old Feb 7, 2010 | 12:25 PM
Alan 71's Avatar
Alan 71
Hi MOS,
I believe there was a bead of black sealer in that space between the trim pieces and painted fiberglass. It turned gray over the years, I guess from exposure to the elements.
The chrome pieces and stainless center piece squished down on the sealer and what was left was smoothed out, but could still be seen with the trim in place.
Regards,
Alan
Old Feb 7, 2010 | 12:31 PM
69ttop's Avatar
69ttop
Default sealent
When I did my restoration I removed the S/S ttop trim. The factory used a grayish putty like sealant that was still pliable after 40 years.
I think it was called Plastisol. I'm not sure you can still get it. I used 3M automotive bedding and glazing compound which stays pliable also.
Old Feb 7, 2010 | 01:48 PM
oldsarge's Avatar
oldsarge
There are both kinds still available. The black product was a 3M caulk at auto shops, and the gray was called " butyl " you can get at a window hardware supply.
Old Feb 7, 2010 | 03:33 PM
manofsteel1
Default Sealant
Thanks guys. That helps out. I wasn't planning on taking off the T Top chrome trim to paint the car. You all think I should? I also take it that the sealant can be painted where it is exposed. Right?
Old Feb 7, 2010 | 03:50 PM
Alan 71's Avatar
Alan 71
Hi MOS,
No,the sealant stays soft and thus doesn't accept paint.
If you drill out the 2 small rivets that go from the ends of the large 'T' shaped piece of ss trim into the 2 long thin pieces of chrome trim the trim is pretty easy to take off. The interior soft trim pieces under the halo do need to be taken off to get to the screws that hold the long thin pieces on.
The first picture shows what you see when you take both the large piece and the 2 long thin pieces off. You may not want to take the large 'T' shaped piece completely off because that involves the trim around the windshield.
You can just see one of the rivets in the fourth picture
Not too big a job.
Regards,
Alan
To T top Question
