Broken speedo cable
Old Feb 21, 2010 | 10:49 AM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
Default Broken speedo cable
My speedo cable is broken. I know I can TRY to go under the dash and TRY to disconnect it from the speedo...here is my question can I take off the guage panel (5 screws I believe) and get access to the cable or do I have to go under the dash? There is no way my sausage link fingers are going to reach the clip! Thanks!
Old Feb 21, 2010 | 12:00 PM
oldsarge's Avatar
oldsarge
You probably have to go down under. There is a whole lot more to removing the panel than just those screws you mentioned. Two things, it is easier to get under with the seat removed, only four bolts and makes alot more room, second, as for your fat fingers, you can use a pair of long handle bent needlenose pliers to push on the speedo cable release. Good luck, it isn't that bad.
Old Feb 21, 2010 | 12:04 PM
larryg3's Avatar
larryg3
it has to be from down under.
Old Feb 21, 2010 | 01:30 PM
Ganey's Avatar
Ganey
Try it w/ a positive attitude, you only need to undo the clip & push back some. Many times it's possible to reach under & release a speedo cable.
Old Feb 21, 2010 | 06:57 PM
Ret.Horsecop13
I figured I would have to go under, but I was hoping there was another way. Is there anything that has to be removed or just get up in there and find the clip? Thanks
Old Feb 21, 2010 | 07:20 PM
oldsarge's Avatar
oldsarge
Just find the clip, push in on it towards the speedo and pull on the cable at the same time, once you have depressed the clip.
Old Feb 21, 2010 | 07:21 PM
Ret.Horsecop13
Thanks Sarge!
Old Feb 21, 2010 | 10:35 PM
FKING1's Avatar
FKING1
You can also access it through thr windshield wiper switch if removed.
That's how I got at my tach clip.
Old Feb 22, 2010 | 07:11 AM
TimAT's Avatar
TimAT
Get some help to gently push on the cable from under the hood, push the clip down and then have your help pull. Beats trying to get 2 hands under the dash while standing on your head.
Old Feb 22, 2010 | 06:34 PM
Ret.Horsecop13
Next question... why are some cables two piece and some one piece? Two vendors from this site sell a one piece for a 72 and a two piece for a 72. They both say for auto or 4 spd. Mine is a 4 spd and has a two piece. Does it matter if I use 1 or 2?
Old Feb 22, 2010 | 08:55 PM
TimAT's Avatar
TimAT
Normally, the 2 piece cable was for the cruise control equipped and the one piece was not. The one piece cable is 72" long
Old Feb 23, 2010 | 05:51 AM
Ret.Horsecop13
I heard that also, I have a two piece... go figure! I definately dont have cruise! Thanks for the help
Old Feb 23, 2010 | 11:23 AM
oldsarge's Avatar
oldsarge
Go figure, my 73 had a two piece also, no cruise either, I guess GM boys, sometimes just grabbed what was closest to them on the shelf.
To Broken speedo cable
