Burning up points?
Old Feb 21, 2010 | 08:22 PM
sting66cp's Avatar
sting66cp
Default Burning up points?
I'm helping a friend troubleshoot an ignition problem on his 71 small block with stock distributor and ignition.
He will burn up a set of points in about 300 to 500 miles. The cap, rotor, plugs, wires, points and condensor are new.
Does this car are have ballast resistor? Could that be the problem? Any idea's ?
Old Feb 21, 2010 | 08:48 PM
blue427's Avatar
blue427
Corvettes have a resistance wire(white fabric looking wire from distributer to engine harness),probably shortened at one time allowing to much voltage to points.Three easy fixes,one,replace resistance wire with new one,two,get a coil with more resistence(some older coils have3.3 ohms of resistence i.e.61 Rambler.three,replace resistence wire with 14 gauge wire and install electronic ignition,H.E.I. Pertonics,Msd.They run on full voltage.
Old Feb 21, 2010 | 09:49 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
It has been a long time since I had a point problem but I recall that if you had a buildup of metal on one side of the points it indicated a problem with the condenser and a buildup on the other side of the points it indicated a problem with the coil. I am sure someone here can elaborate. Not sure if this info will help you but it may.
Old Feb 21, 2010 | 10:13 PM
lars's Avatar
lars
There are only a few things that will cause the points to burn:
  1. Failure to use the resistance wire. The '71 uses a cloth-wrapped resistance wire which serves the same function as the old ballast resistor. If the wire has been bypassed or altered, the points will burn. If this is the case, install a ballast resistor in its place.
  2. Bad condenser. Replace the condenser with NAPA part number RR175
  3. Dwell (point gap) grossly out of spec. Set dwell to 30-31 degrees.
Lars
Old Feb 22, 2010 | 09:25 AM
7T1vette's Avatar
7T1vette
He might also have replaced the coil with a "hotter" unit [not made to use with a ballast resistor, or made for use with electronic ignition].
Old Feb 22, 2010 | 10:49 AM
hugie82's Avatar
hugie82
I would pick up a points eliminater kit. Screws in very easy, set gap, run 12v ign. to it and forget it. No one will ever know because it all under the cap.
Old Feb 22, 2010 | 01:42 PM
71coupe454's Avatar
71coupe454
I ran my engine on a stand several times with full 12 volts and burned up the points fast! Had turned blue from heat..
Old Feb 22, 2010 | 09:01 PM
sting66cp's Avatar
sting66cp
Lars
Found the problem, the dwell was way off...
To Burning up points?
