Parking brake option
Old Feb 22, 2010 | 04:33 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Parking brake option
This will of course require some fabrication, but looks like it could be an option to the poor factory design our C3's have.
http://www.jegs.com/p/Wilwood/Wilwoo...57779/10002/-1
Sample pic of install:
Old Jul 15, 2010 | 01:32 PM
taylorbg's Avatar
taylorbg
Did you do it and did it work?
Old Jul 16, 2010 | 10:06 AM
carbster09's Avatar
carbster09
Default Awesome set up
Wow, is that your set up? What is the spec of the AP Racing set up?? I love it. I want that small wilwood caliper for my Parking brake as well. One day when I have time!
Old Jul 16, 2010 | 11:50 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I don't think that Wilwood Spot Caliper will work. It says max rotor with is .81. C3 rotors are 1.254 new and min thickness is 1.215.
http://www.wilwood.com/Calipers/Cali...x?subname=Mech Spot
Old Jul 16, 2010 | 11:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by SmokedTires
...looks like it could be an option to the poor factory design our C3's have....
I'll keep the stock set up.
Old Jul 17, 2010 | 03:16 AM
Solid LT1's Avatar
Solid LT1
X2 the one in the photo is "The POOR SET-UP"
Old Jul 17, 2010 | 05:59 PM
SmokedTires
St. Jude Donor '05
No I haven't yet. I'm in the process of painting my car so probably a next summer mod. Norval did this and claimed it worked great on his car. Van Steel is correct about the rotor spacing which is another reason I haven't gotten to it yet, still need a 3 phase convertor for my Bridgeport mill to make the necessary caliper spacers. Norval also has the dual master cylinders actuated by the stock hand brake with everything under the stock E-brake handle housing.
Will update when I get to it
Old Jul 17, 2010 | 09:22 PM
SmokedTires
St. Jude Donor '05
A couple pics of calipers mounted;
To Parking brake option
