help my vette is dead!!!!
Old Jul 17, 2010 | 08:20 PM
corieb's Avatar
corieb
Default help my vette is dead!!!!
I took off my starter motor harness to fix a bare wire .
I put it back on and the car went nut's ,non of the light's work and when i tried to start the car .
It started on the first turn and not the second ????
Then i tried to turn the car off ,i had to disconnect the battery to get it to turn off ??????.
Need help to fix this plz.
P.S
I ordered a new starter motor harness cc will get on Thursday.
Old Jul 17, 2010 | 08:31 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Maybe you mis-wired it?
Old Jul 17, 2010 | 08:37 PM
stpman's Avatar
stpman
check in the canadian section, there are many forum members in your area that could help
Old Jul 17, 2010 | 09:23 PM
rx3191's Avatar
rx3191
mite be miswired, check to make sure the starter signal wire is on the S terminal of the solenoid and not the I, the I terminal was for the old points ignition systems and provided 12 volts to the ignition system during cranking only, but i know if you hook up the starter signal wire to that terminal it will continue to crank after you release the key
To help my vette is dead!!!!
